simpleFoam case exits before starting the loop
Old   April 17, 2023, 19:31
Default simpleFoam case exits before starting the loop
samwise14 is on a distinguished road
Hello, I'm trying to run a case of a wind turbine in simpleFoam. The problem is after creating the mesh and starting simplefoam it exits before the first time loop without error message. At first i thought about non manifoldness on the geometry but I checked it in SolidWorks and Spaceclaim and has no errors.
I let the case folder without the geometry (to big to upload here) here for you to check.
MWthicknessmanifold.zip
This is the simpleFoam output when running it in parallel. When i run it normally it doesnt even show the error message.
Create time
Create mesh for time = 0
[DESKTOP-LKQMJQQ:04290] 5 more processes have sent help message help-btl-vader.txt / cma-permission-denied
[DESKTOP-LKQMJQQ:04290] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
SIMPLE: convergence criteria
field p tolerance 0.001
field U tolerance 0.0001
field "(k|epsilon)" tolerance 0.0001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[52973,1],3]
Exit code: 142
samwise14 is offline   Reply With Quote
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
simpleFoam - errors in a simplified room ventilation case (my first simulation) tfigueiro OpenFOAM Running, Solving & CFD 3 April 8, 2015 18:37
Experimental data vs SimpleFoam sphere test case : Cd do not match alsdia OpenFOAM Verification & Validation 1 November 2, 2012 06:37
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 02:30
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
