Running airfoil simulation with kOmegaSST mdodel with y+ below 1
Old   April 16, 2023, 15:08
Default Running airfoil simulation with kOmegaSST mdodel with y+ below 1
jaydarji395 is on a distinguished road
Hey guys,
I am trying to simulate NACA 0012 airfoil to learn and to get correct results for validation. I have created my mesh in blockMeshDict with 12 blocks which consists of 6 outer and 6 inner blocks. Well, I tried to simulate at AoA= 4 degree with y+=0.05. The input data is: Re=1e06, U=14.60734694 m/s, nu= 1.460734694e-05 m²/s, rho = 1.225 kg/m³. I am getting this weird wake region where the velocity, pressure and turbulence parameters are discontinuous, as can be seen from the figure. I have attached the boundary conditions and I am using pisoFoam algorithm to solve it. My assumption is that the 1st cell height being too small of the order 1e-06, and time step being 1e-05, I am getting this. The max Co= 45 nearly. I will post Co field as well.
My questions are: 1) Should I use this small cell height with kOmegaSST model?
2) I have also tried to use y+=1.5, i.e. 5e-05m height of first cell, and ran the simulation for AoA=4 degree. For this the maxCo at the end is 0.112129.
I get the Cd and Cl values 2.202755e-02, 3.365725e-01 respectively. These results do not agree with say Ladson or Xfoil results which are: 0.00728, 0.4276. What should I do to improve or to correct the results?
The coefficients I got with y+=0.05 were fluctuating, because of the reason I have described above.
jaydarji395 is offline   Reply With Quote
Simulation just stops output writing, but keeps running blaise OpenFOAM Running, Solving & CFD 6 March 27, 2024 05:49
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 14:46
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 10:38
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
NO STAGNATION POINT FOR AIRFOIL SIMULATION Rif Main CFD Forum 6 February 4, 2008 08:33
