Calculation of drag force and yaw moment of catamaran hull |
Alexander Stroganov
Rep Power: 3 ![]() |
Good day.
For catamaran hulls hydrodynamic passports we need calculate forces and moments of force for geometric shapes in flow. For that purpose we have build CfdOF case and post-process Python script. All data is open and we will upload case and results on gitHub. Problem is I am not understand correctly that pressure mean in OpenFoam. Script for calculation of drag force and yaw moment of the hull 1. Wigley body Pressure difference between bow and stern (force of resistance to rectilinear motion): 23.282568642571178 kgf Pressure difference on the starboard and port side (drift force): 957.3720653957847 kgf Pressure difference between bow and stern along the XZ plane (turning force): 310.2378232213018 kgf 2. Darth18 case Pressure difference between bow and stern (force of resistance to rectilinear motion): 52.29271371957253 kgf Pressure difference on the starboard and port side (drift force): 707.3221705652993 kgf Pressure difference between bow and stern along the XZ plane (turning force): 460.9348338505562 kgf 3. Body Knife Pressure difference between bow and stern (resistance force to rectilinear motion): 39.956765095057506 kgf Pressure difference on the starboard and port side (drift force): 1255.2393975077616 kgc Pressure difference between bow and stern along the XZ plane (turning force): 350.90999322729 kgf 4. Body - stem cylinders or pirogues Pressure difference between bow and stern (resistance force to rectilinear motion): 30.53412464362008 kgc Pressure difference on the starboard and port side (drift force): 681.7223724508121 kgf Pressure difference between bow and stern along the XZ plane (turning force): 220.89399426653483 kgc 5. Body AUF (inflatable carrot, blunt end first) Pressure difference between bow and stern (resistance force to rectilinear motion): 33.04866398583098 kgc Pressure difference on the starboard and port side (drift force): 435.42133515210753 kgc Pressure difference between bow and stern along the XZ plane (turning force): 74.1517491635035 kgf Calculation for catamaran hulls of equal length and displacement at a flow rate of 3m/s at a drift angle of 30 degrees. Corresponds to the angle of drifting in close-hauled, towing and bulking of the hull against an obstacle by the force of a current or a large wave. Body length 5m, frame width 2m. The total displacement of each hull is 670 kg. The calculation was carried out for a completely submerged body without taking into account wave formation. Catamaran_hull_flow_p.jpg |
pressure and density |
moving and floating catamaran case solver | CenterRime | OpenFOAM Running, Solving & CFD | 7 | December 19, 2023 16:59 |
Script for calculation of drag force and yaw moment of the hull | CenterRime | OpenFOAM Post-Processing | 0 | April 9, 2023 23:26 |
The CoP Does not exist: Validating Aerodynamic forces through a "line of action" | ds4719 | Main CFD Forum | 14 | February 18, 2022 18:05 |
Force coeff. calculation for crosswind DES | krembil | FLUENT | 0 | September 3, 2012 10:35 |
