Openfoam 10 tutorial Propeller : error with addLayers true
Old   April 6, 2023, 07:46
Default Openfoam 10 tutorial Propeller : error with addLayers true
Kevin
KevinC is on a distinguished road
I'm working on the tutorial Propeller on OpenFOAM 10, I have adapted it to my case, but my question is for the tutorial itself.
Everything is working fine, except when I switch addLayers false; to addLayers true;
The mesh is correctly done but when pimplefoam starts, I got this error at the first iteration :
PIMPLE: Iteration 1
patchToPatch: Calculating couplings between 22416 source faces and 22416 target faces
Source min/average/max coverage = 0.868231/0.999946/1
Target min/average/max coverage = 0.867585/0.999946/1
Source average openness/error/depth/angle = 1.54044e-16/2.79402e-06/0.0010975/0.099102
Source max openness/error/depth/angle = 7.14646e-16/0.0117205/0.00742731/2.7834
197878 couplings calculated in 0.210863s
fvMeshStitcher: Connecting
double free or corruption (out)
[ip-172-31-38-173:459888] *** Process received signal ***
[ip-172-31-38-173:459888] Signal: Aborted (6)
The only difference is the prism layer..
Does anyone have an idea what could be the problem?
Thanks in advance,
Regards
Kevin
KevinC is offline   Reply With Quote
addlayers, openfoam10, propeller
Turning the Tutorial propeller case into a flow driven case with 6Dof efirvida OpenFOAM 0 March 7, 2017 10:45
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 10:04
Running propeller tutorial !! S.E. Kwon OpenFOAM Running, Solving & CFD 0 October 27, 2014 23:01
reactingFoam tutorial for OpenFOAM 2.1.0 ToTh OpenFOAM Running, Solving & CFD 1 September 3, 2012 05:43
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
