mpirun exit code 142
Old   April 5, 2023, 05:28
Post mpirun exit code 142
mithun
mithuntmanoj is on a distinguished road
I'm having trouble conducting a simulation in open foam; the simulation model is RANS k-w SST. Does anyone knows the the exit code error 142 and how to resolve the issue.
(error file is given below)
Time = 1
Solving for fluid region fluid0
U (0 0 0)
UL (0 0 0)
Re 0
alpha 0
PI1x 152.963
PI1y 0
Primary job terminated normally, but 1 process returned
a non-zero exit code.. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[15418,1],1]
Exit code: 142
mithuntmanoj is offline   Reply With Quote
Old   April 5, 2023, 18:08
Ching Liu
qingqingliu is on a distinguished road
You can run without using MPI. It will show more detailed info about the error.
qingqingliu is offline   Reply With Quote
exitcode142, openfoam
Non-Zero exit code of: 2 KUAlex CFX 18 April 12, 2024 08:21
The solver failed with a non-zero exit code of : 2 ERROR taneradil CFX 1 March 30, 2023 19:14
water injection error (modify the position of water injection) wjchoi Main CFD Forum 0 January 17, 2022 08:17
Crash with Exit code 1073741819 Jasmina92 ANSYS 2 October 23, 2018 06:33
The FOAM Documentation Project - SHUT-DOWN holger_marschall OpenFOAM 242 March 7, 2013 13:30
