How to run OpenFOAM on overclocked CPU?
Old   April 5, 2023, 00:22
Question How to run OpenFOAM on overclocked CPU?
Konstantin Lebeda
Konstant1n is on a distinguished road
Hello! I`m trying to run OpenFOAM simulation on Intel core I9-9980XE overclocked by 4.8 GHz, but it runs only 3.8 GHz. There no throttling, temperatures are low.
To run simulation I use this line:
mpirun -np 16 rhoPimpleFoam -parallel
What should I do to increase CPU frequency?
Konstant1n is offline   Reply With Quote
Old   April 7, 2023, 08:36
Paulo Vatavuk
vatavuk is on a distinguished road
Hi Konstantin,
We worry about the number of cores and frequency of the processors, but the experts say that what normally limits the performance of computers is the communication between the processors and RAM memory. People say that a dual channel system works well with up to about 4 cores. A four channel system like yours should work well with up to 8 cores. Using more cores won’t make the system faster because the processors will have to wait for the information to be retrieved from memory.
If you are worried about the performance of your system, you can run the motorbike benchmark and compare the results with the ones reported in this thread:
OpenFOAM benchmarks on various hardware
vatavuk is offline   Reply With Quote
Problem with parallel run on OpenFoam stater OpenFOAM Running, Solving & CFD 0 March 15, 2023 10:05
OpenFOAM Training, London, Chicago, Munich, Houston 2016-2017 cfd.direct OpenFOAM Announcements from Other Sources 0 September 14, 2016 04:19
Unable to run a case with OpenFOAM 1.6-ext that works with OpenFOAM 2.3.0 Jiricbeng OpenFOAM Running, Solving & CFD 15 May 21, 2014 04:52
Running damBreak with OpenFOAM 15 and Open MPI on mixed up CPU Systems engys OpenFOAM Running, Solving & CFD 8 November 26, 2008 05:57
OpenFOAM 13 Intel quadcore parallel results msrinath80 OpenFOAM Running, Solving & CFD 13 February 5, 2008 06:26
