Simulating motion due to internal sloshing loads |
chris
Rep Power: 15 ![]() |
I am trying to find a solution to modelling sixdof motion of a container partially filled with liquid that should respond to the loads induced by the internal motion of the fluid, as well as the restraints and constraints. As far as I can tell from my tests so far, the sixdof solver does not include these loads, and would only include "external" aerodynamic loads in determining the motion. What would be the best way to go about simulating this? Do I need to modify the source of sixDofSolver to somehow integrate the internal pressures, then add this as an additional force along with the restraints? Or is there a simpler way? Thank you! |
sixdof, sloshing, vof |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
Simulating reciprocating motion in Maxwell. | broli | ANSYS | 0 | April 20, 2012 09:44 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 14:17 |
InterDyMfoam gives strange gamme if cell volume changes due to mesh motion | daniels | OpenFOAM Running, Solving & CFD | 8 | April 7, 2009 09:31 |
Motion of cylinder due to vortex shedding | ACHILLEAS TSOMPANOS | FLUENT | 3 | November 24, 2006 03:06 |
