FATAL ERROR by redistributePar for a modified snappyMultiRegionHeater tutorial
Old   March 27, 2023, 15:16
Default FATAL ERROR by redistributePar for a modified snappyMultiRegionHeater tutorial
RT
Ryôzanpaku Tiger is on a distinguished road
Dear all,
I have modified the OpenFOAM (v2212, OpenFOAM using Docker on macOS Ventura 13.2.1) tutorial case heatTransfer/chtMultiRegionFoam/snappyMultiRegionHeater by adding a sphere to the topAir part. A sphere is given by the STL file, located in resources/ folder, addded to the case floder.
The original case runs flawlessly, however, the updated case produces a FATAL ERROR when calling redistributePar utility:
Decomposition method scotch [4] (region sphere)
From time 0 mesh:"constant/sphere" have objects:4(rho cellToRegion p T)
[3] [0]
[0]
[0] --> FOAM FATAL ERROR: (openfoam-2212)
[0] Cannot find a patch which is not of type empty, mapped or coupled in patches 1(sphere_to_topAir)
There has to be at least one such patch for distribution to work
[0]
[0]     From Foam::label Foam::fvMeshDistribute::findNonEmptyPatch() const
[0]     in file fvMeshDistribute/fvMeshDistribute.C at line 362.
[0]
FOAM parallel run aborting
I also changed the endTime to 0.001 (just to run few steps and see the behavior of reconstructPar afterwards as well) and the number of processors to 4.
I checked thouroghly all modifications, but can't find the error. I would very appreciate any help or hint.
Here is a Dropbox link to the modified case: the modified case
Thanks!
Ryôzanpaku Tiger is offline   Reply With Quote
chtmultiregionfoam, openfoam 2212, redistributepar, snappymultiregionheater
chtMultiRegionFoam: problem with the tutorial samiam1000 OpenFOAM 21 January 25, 2020 17:32
Modified the motorBike tutorial, getting very high drag ben1793 OpenFOAM Running, Solving & CFD 4 August 16, 2013 03:25
Problem on Fluent Tutorial: Horizontal Film Boilig Feng FLUENT 2 April 13, 2013 06:34
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
