FOAM Warning :From function void Foam::
Old   March 27, 2023, 06:50
Default FOAM Warning :From function void Foam::
harshavardhan
harsha002 is on a distinguished road
Hi I would like to understand what does the following warning signify.
--> FOAM Warning :
From function void Foam:article::locate(const vector&, const vector*, Foam::label, bool, const Foam::string&)
in file particle/particle.C at line 481
Particle initialised with a location outside of the mesh when tracking from centre (3.118266e-016 -2.290438e-016 0.003991597) of cell 1265637 to position (0.001122682 0.001652406 0)
harsha002 is offline   Reply With Quote
Old   March 27, 2023, 08:22
piu58's Avatar
Uwe Pilz
piu58 is on a distinguished road
You have a particle outside of the mesh, which is useless.
Uwe Pilz
Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950)
piu58 is offline   Reply With Quote
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' muth OpenFOAM Running, Solving & CFD 3 August 27, 2018 05:18
[mesh manipulation] RefineMesh Error and Foam warning jiahui_93 OpenFOAM Meshing & Mesh Conversion 4 March 3, 2018 12:32
[snappyHexMesh] Problem with parallel run of snappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 5 April 15, 2016 05:12
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
