Wrong lift and drag coefficients for ahmedbody simulaiton
Old   March 26, 2023, 18:26
Post Wrong lift and drag coefficients for ahmedbody simulaiton
AMR96 is on a distinguished road
I have to simulate external aerodynamics around a vehicle while turning using OpenFoam. Since I have never used OpenFoam before, I am trying to start from something more simple. I have been trying to simulate the flow around an Ahemdbody on a straight line. The dimensions of the domain are 15m x 1.87m x 1.4m and the Ahemdbody is placed in the middle of the channel. I have cut the domain in half in order to save computational power and time.
I already managed to do this simulation on Ansys and got good results for the lift and drag coefficients but I just can't get the same results on OpenFoam. I am using the same mesh that I used in Ansys by importing it into OF using the fluent3DMeshToFoam feature.
I am running the simulation using simpleFoam with realizable k-epsilon model. The residuals seem to decrease to the order of 1e-4 however the lift and drag coefficients keep oscillating in the range of 0.3-0.4 and never approach the experimental values. I ran the simulation for 1000 iterations.
Below I have provided the boundary conditions that I used, also attached you can find the fvscheme, fvsolution, and the last 50 iterations of the simulation.
I would appreciate any help that would guide me in the right direction and help me find where the problem is.
Here is the checkMesh results which seems to be ok.
Mesh stats
    internal points:  564818
    faces:            6232198
    internal faces:   6154064
    cells:            3040478
    faces per cell:   4.0737877
    boundary patches: 5
    point zones:      0
    face zones:       1
    cell zones:       1
Overall number of cells of each type:
    hexahedra:     0
    prisms:        224350
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    2816128
    polyhedra:     0
Checking topology...
    Boundary definition OK.
    Cell to face addressing OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
    Patch               Faces    Points   Surface topology
    inlet               130      100      ok (non-closed singly connected)
    outlet              132      101      ok (non-closed singly connected)
    ground              22220    11398    ok (non-closed singly connected)
    car                 22650    11491    ok (non-closed singly connected)
    symmetry            33002    18681    ok (non-closed singly connected)
Checking faceZone topology for multiply connected surfaces...
    FaceZone            Faces    Points   Surface topology
    interior-geom-enclosure_enclosure6154064  605703   multiply connected (shared edge)
  <<Writing 605001 conflicting points to set nonManifoldPoints
Checking basic cellZone addressing...
    CellZone            Cells        Points       Volume       BoundingBox
    geom-enclosure_enclosure 3040478      605703       19.579551    (-1.1268994 -0.7405 -7.448) (0.27310058 0.1945 7.552)
Checking geometry...
    Overall domain bounding box (-1.1268994 -0.7405 -7.448) (0.27310058 0.1945 7.552)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (1.7931218e-15 -7.4856584e-16 4.2947788e-18) OK.
    Max cell openness = 3.0197195e-16 OK.
    Max aspect ratio = 8.2230522 OK.
    Minimum face area = 4.082886e-07. Maximum face area = 0.020149883.  Face area magnitudes OK.
    Min volume = 1.09952e-10. Max volume = 0.0012024398.  Total volume = 19.579551.  Cell volumes OK.
    Mesh non-orthogonality Max: 66.847134 average: 15.459832
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 2.3554795 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
Here are the boundary conditions:
U
internalField   uniform (0.0 0.0 -40.0);
boundaryField
    inlet
            type            fixedValue;
            value           uniform ( 0.0 0.0 -40.0 );
    ground
        type        fixedValue;
        value       uniform (0 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    car
        type            fixedValue;
    symmetry
        type        symmetry;
pressure
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0.0;
boundaryField
    inlet
        type        zeroGradient;
    ground
        type        zeroGradient;
    outlet
        type            fixedValue;
        value           uniform 0;
    car
        type        zeroGradient;
    symmetry
        type        symmetry;
epsilon
dimensions      [0 2 -3 0 0 0 0];
internalField   uniform 34.56;
boundaryField
    inlet
         type            fixedValue;
         value           $internalField;
    ground
        type        epsilonWallFunction;
    outlet
        type        inletOutlet;
        inletValue  $internalField;
    car
    symmetry
        type        symmetry;
k
internalField   uniform 0.24;
boundaryField
    inlet
        type            fixedValue;
    ground
        type        kqRWallFunction;
    outlet
        type            inletOutlet;
    car
    symmetry
        type        symmetry;
AMR96 is offline   Reply With Quote
Old   March 28, 2023, 10:35
Can anybody help please )
convergance, drag and lift, openfoam, residual, simplefoam convergence
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
How to not overwrite drag and lift coefficients after a simulation Giovanni Trovato FLUENT 1 August 1, 2018 01:31
wrong SU2 calculation for lift and drag coefficient for NAC4421 mechy SU2 7 January 9, 2017 06:18
Correct lift but wrong pressure drag - possible? zx Main CFD Forum 4 July 28, 2007 00:38
Lift and Drag Coefficients Reliability Luis FLUENT 2 December 27, 2005 15:45
