create fields for arguments that are created in the middle of a calculation
Old   March 23, 2023, 20:42
Default create fields for arguments that are created in the middle of a calculation
Sangmin Kim
sm0226 is on a distinguished road
Hello.
I am currently conducting a combustion analysis using OF-v2112.
In the code below, specifically in inhomogeneousMixture.C, 'ox' (oxidant mass fraction) is being calculated.
I would like to generate this as a single field.
I need your advice.
Thank you.
// * * * * * * * * * * * * * * * Member Functions * * * * * * * * * * * * * //
template<class ThermoType>
const ThermoType& Foam::inhomogeneousMixture<ThermoType>::mixture
const scalar ft,
const scalar b
) const
if (ft < 0.0001)
return oxidant_;
else
scalar fu = b*ft + (1.0 - b)*fres(ft, stoicRatio().value());
scalar ox = 1 - ft - (ft - fu)*stoicRatio().value();
scalar pr = 1 - fu - ox;
mixture_ = fu*fuel_;
mixture_ += ox*oxidant_;
mixture_ += pr*products_;
return mixture_;
sm0226 is offline   Reply With Quote
Old   March 24, 2023, 10:04
Yann
Yann will become famous soon enoughYann will become famous soon enough
I have absolutely no experience with your solver, but if the variable is registered in the database you can try to use the writeObjects function:
https://develop.openfoam.com/Develop...writeObjects.H
I hope this helps,
Yann
Yann is offline   Reply With Quote
Meshing a Sphere Ajay FLUENT 10 September 3, 2016 15:18
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 10:15
How to create a vector field out of scalar fields anja OpenFOAM Pre-Processing 7 May 31, 2006 12:56
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
