Non smooth discontinuties contour solution at grid size transistion region |
March 15, 2023, 23:19 |
TWB
Rep Power: 19 |
I'm trying to simulate a 2D flow past airfoil. The grid is generated by SHM, as attached. Grid size is about 0.9M. The solver used is pimpleFoam and Re tested are 100 - 10000. The forces reached a reasonable steady state after a while. However, there are discontinuties in the velocity contours when the grid changes from coarse to fine, as shown. I have simulated different grids using SHM but I'm not sure why this happens. I tried to increase the grid resolution but the problem is still there. Can someone enlighten me? |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 04:01 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 09:19 |
Grid Independent Solution | Chuck Leakeas | Main CFD Forum | 2 | May 26, 2000 12:18 |
Grid Quality and the Solution | Faraz | Main CFD Forum | 4 | January 10, 2000 19:18 |
