March 15, 2023, 10:05 |
Problem with parallel run on OpenFoam
#1 | |
H. Omar
Rep Power: 13 |
Hi everybody,
I set up a small computing cluster to run calculations on OpenFoam, but I can't run a job on multiple nodes. I am using the following sbatch file: Quote:
I can run this job in parallel on a single node with two cores, but when I run it on two different nodes, nothing happens in the "processor" directories. I checked on the nodes on the nodes the processes actually launch, but I have no results on the sharing directory. I am using OpenFoam 22.12 with openmpi 4.1.2 and slurm 21.08.5. My network is Ethernet 1Gb/s. I checked the NFS server and write permissions, everything is OK Could anyone help me!!! Thank you!!! |
openfoam 10, openmpi 4, parallel calculation |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
[snappyHexMesh] Problem with parallel run of snappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 5 | April 15, 2016 05:12 |
p_rgh problem during parallel run | musahossein | OpenFOAM Running, Solving & CFD | 0 | November 23, 2014 10:01 |
OpenFOAM doesn't run in parallel | callumso | OpenFOAM Running, Solving & CFD | 0 | July 11, 2013 13:17 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 18:11 |
