Coarse mesh case runs but fails when mapped to finer mesh
Old   March 10, 2023, 05:03
Default Coarse mesh case runs but fails when mapped to finer mesh
Jnana Bhaskar Rao
jnanabrao is on a distinguished road
I am running a Mach 2 jet LES calculation with dynamicKEqn using sonicFoam. It runs on a coarse mesh (200k cells). But when I map it to a fine mesh (25mil cells) with mapFields and same boundary conditions and run it, I get a sigFpe error in calculation of Eddy diffusivity in the correctNut function.
Selecting finite volume options model type limitTemperature
    Source: limitT
    - selecting all cells
    - selected 25291152 cell(s) with volume 0.0341883194
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in "/lib64/libc.so.6"
#3  Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  Foam::LESModels::dynamicKEqn<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::Ck(Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
#6  Foam::LESModels::dynamicKEqn<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correctNut(Foam::GeometricField<Foam::SymmTensor<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#7  Foam::LESModels::dynamicKEqn<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correctNut() at ??:?
#8  ? at ??:?
#9  __libc_start_main in "/lib64/libc.so.6"
#10  ? at ??:?
The error seems to originate in evaluation of Ck, particularly in evaluating the square root of field KK which is surprising as KK represents the subgrid kinetic energy and is obtained as :
volScalarField KK
        0.5*(filter_(magSqr(this->U_)) - magSqr(filter_(this->U_)))
My question is how do I resolve this? Ideally I would like to know if there is a reason why this works for the coarse mesh but not the fine one.
Any help is deeply appreciated.
JBR
jnanabrao is offline   Reply With Quote
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
Initial condition data file from coarse mesh case fra d'amb OpenFOAM Pre-Processing 1 September 6, 2015 13:29
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
Oscillating Residuals in Finer Mesh Case Jake FLUENT 3 June 16, 2005 10:34
