chtMultiRegionFoam for solid surface temperature modeling
Old   February 23, 2023, 09:21
Post chtMultiRegionFoam for solid surface temperature modeling
Fotis Anagnostopoulos
efalpha is on a distinguished road
I am studying surface temperature anisotropies induced by geometry anisotropies during heating/cooling of solid objects, using ChtMultiregionFoam. In particular, I modify the 'coolingSphere' tutorial by using an .stl file instead of the sphere. In my case there is a hollow cylinder (with thickness asymmetries). After long debugging, i managed to solve all the problems of type "FOAM FATAL ERROR". Now, there is an error of type "SIGPE" (perhaps division with zero?) right after the solver reads the "fluid mesh thermophysical properties for region fluid1" at log.chtMultiregionFoam (i include it).
(Apart from the particular issue, I am not sure if "chtMultiRegionFoam" solver is optimal for my problem, so i would also appreciate any thoughts in this direction. )
Thank you in advance for any suggestions/ideas. I would gladly share any info you deem useful.
efalpha is offline   Reply With Quote
Old   March 1, 2023, 09:31
Default Solution: T != 0
I am posting this for future reference: The problem was appearing after loading thermodynamic properties, so i thought it has to do with the Temperature being 0. Indeed, by setting a non-zero temperature at BC for T (i.e. "internalField uniform 300;") problem solved.
I still have errors, however i will post in another thread.
chtmultiregionfoam, solid air interface
Simulating the surface temperature of an aircraft - which approach is sufficient? CellZone Main CFD Forum 3 February 26, 2023 14:10
Weird (unphysical) temperature rise with chtMultiRegionFoam Phil910 OpenFOAM Running, Solving & CFD 3 November 9, 2022 10:25
Temperature issue during modeling cooling plate using Star CCM+ tjushang STAR-CCM+ 2 August 22, 2021 23:43
Solution not converging with Surface Tension modeling faizan356 Fluent Multiphase 0 July 28, 2021 03:53
Error in gmshToFoam on ESI v2106 siefer92 OpenFOAM Programming & Development 4 July 17, 2021 06:11
