icoReactingFoamMultiphaseInterFoam diffusion problem in one phase |
February 23, 2023, 09:09 |
guo
Rep Power: 4 |
I want to ask this solver whether or not can simulate the species diffusion problem in one phase. I have changed the inertMultiphaseMultiComponent case which is shown in the openfoam V2206. I change this case into one phase, but the simulation can not be continued with the mistake shown in there. Thank you for help solving this problem.
Create time Create mesh for time = 0 PIMPLE: no residual control data found. Calculations will employ 2 corrector loops Reading field p_rgh Reading field U Reading field T Calculating field g.h Reading g Reading hRef Calculating field g.h Creating multiphaseSystem Selecting multiphaseSystem massTransferMultiphaseSystem Selecting phaseModel for gas: multiComponentMovingPhaseModel Selecting thermodynamics package { type heRhoThermo; mixture multiComponentMixture; transport const; thermo hConst; equationOfState incompressiblePerfectGas; specie specie; energy sensibleEnthalpy; } Selecting turbulence model type laminar Selecting laminar stress model Stokes Radiation model not active: radiationProperties not found Selecting radiationModel none Calculating field rhoCp Creating field kinetic energy K DICPCG: Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 0, global = 0, cumulative = 0 No finite volume options present Courant Number mean: 0 max: 0 Starting time loop Courant Number mean: 0 max: 0 Interface Courant Number mean: 0 max: 0 Maximum ddtAlpha : 0 Maximum DiffNum : 0 deltaT = 1.2e-06 Time = 1.2e-06 DILUPBiCG: Solving for alpha.gas, Initial residual = 0, Final residual = 0, No Iterations 0 MULES: Solving for alpha.gas Phase-sum volume fraction, min, max = 0.5 0 1 alpha.gas volume fraction = 0.5 Min(alpha) = 0 Max(alpha) = 1 |
Add diffusion between selected phase pairs in multiphaseeulerfoam | tom_flint2012 | OpenFOAM Programming & Development | 5 | February 6, 2019 08:11 |
problem in definition of secondary phase volume fraction in UDF | hadii | FLUENT | 9 | July 20, 2016 05:46 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
Time unit in finite volume solution for diffusion problem. | alpha2beta | Main CFD Forum | 0 | June 30, 2010 03:05 |
simple diffusion problem | sosat1012 | CFX | 2 | May 25, 2010 09:33 |
