chtMultiRegionSimpleFoam- Conjugate Heat Transfer Airfoil
Old   February 22, 2023, 20:34
Unhappy chtMultiRegionSimpleFoam- Conjugate Heat Transfer Airfoil
B_SZ is on a distinguished road
Hello everyone,
I am kinda new using the Heat Transfer solver of OpenFoam.
I would like to see the aerodynamic impact of imposing a heat load at multiple angle of attack on a 2D-Airfoil .
I was thinking first to use the steady state version of chtMultiRegionFoam.
It seems I have issues with my boundary Conditions and my Fv files.
Maybe someone has a better idea on how I can do this case?
Below my error Message and my case.
https://drive.google.com/file/d/1K8T...usp=share_link
Thank you for Reading.
--> FOAM Warning : Creating fvConstraints from "system/fvOptions"
Selecting finite volume constraint type limitTemperature
- selecting all cells
- selected 24402 cell(s) with volume 857.29064
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
#5 Foam::fluidThermo::nu() const at ??:?
#6 Foam::RASModel<Foam::compressibleMomentumTransport Model>::nu() const at ??:?
#7 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::compressibleMomentumTransportModel> >, Foam::compressibleMomentumTransportModel>::F2() const at ??:?
#8 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::compressibleMomentumTransportModel> >, Foam::compressibleMomentumTransportModel>::F23() const at ??:?
#9 Foam::kOmegaSST<Foam::eddyViscosity<Foam::RASModel <Foam::compressibleMomentumTransportModel> >, Foam::compressibleMomentumTransportModel>::correct Nut() at ??:?
#10 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
Floating point exception (core dumped)
B_SZ is offline   Reply With Quote
airfoil 2d, conjugate heat transfer
No conjugate heat transfer between solid (cast iron) and fluid (water) part Rajaero FLUENT 5 June 25, 2023 04:07
Cyclic conjugate heat transfer johanesp OpenFOAM Programming & Development 0 December 30, 2021 11:55
No conjugate heat transfer between solid (cast iron) and fluid (water) Rajaero Main CFD Forum 1 August 23, 2018 14:01
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? MaxHeat FLUENT 4 September 14, 2017 11:44
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
