Trouble with cell mapping in chtMultiRegion case
Old   February 22, 2023, 15:40
Default Trouble with cell mapping in chtMultiRegion case
Alan w
boffin5 is on a distinguished road
For a long time I have been working with a simulation involving an aircraft fuselage with a ventral radiator. I am simulating the radiator with a simple cuboid modelled as a porous volume, as part of a chtMultiRegion setup. When I attempt to run the case, it fails, with the message:
"FOAM FATAL ERROR - Plane normal defined with zero length."
How can I resolve this?
When I run the simulation without the radiator as a simpleFoam case, it runs fine, as can be seen with the pressure contours in the attached image. But adding the radiator for a chtMultiRegion case leads to problems. I have attached three more images showing cross sections in different directions to illustrate the installation of the radiator.
Following advice that I found in other posts, I changed the interpolationMethod in fvOptions from cellVolumeWeight to mapNearest. However, the result of this was the case running endlessly, and I finally had to kill it.
I am hoping for advice, especially as this is my graduation case; if I can pull it off, it will be the conclusion of my openFoam tools development, and the beginning of really using it productively!
File Type: png SnapCrab_NoName_2023-2-22_10-56-21_No-00.png (113.9 KB, 3 views)
boffin5 is offline   Reply With Quote
plane
case to show Meredith Effect - but trouble boffin5 OpenFOAM Running, Solving & CFD 3 March 12, 2022 17:02
UDF in case with DPM modle POSTHU Fluent UDF and Scheme Programming 0 March 3, 2021 08:21
Trouble with simple case for a new OpenFOAM user jdw135 OpenFOAM 2 October 18, 2020 21:26
[snappyHexMesh] snappyhexmesh cell splitted ununiform..2D case sharonyue OpenFOAM Meshing & Mesh Conversion 1 April 23, 2013 00:34
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
