k omega SST for heat transfer
Old   February 22, 2023, 08:09
Default k omega SST for heat transfer
Nico
Hr_kules is on a distinguished road
Hey guys,
i am running the k omega SST model for a series of simulations and in my old lecture notes was the recommendation that if heat transfer is important one should use the k omega SST with a y+ of 1, 10-20 number of layers and growth rate of 1.2. This works so far, but i need/want to understand my simulation better.
For the first layer height i used the calculator from this website https://www.cfd-online.com/Tools/yplus.php. I can mesh that with snappyHexMesh and Gmsh, no problem whatsoever, however if i run my simulation the y plus function object prints:
patch wallDeveloped y+ : min = 0.0048604, max = 0.00530782, average = 0.00514233
How can this happen if the y+ used to calculate the height was 1?
How do wallfunction for k, omega and alphaT come into place? Are they even needed? Or should i leave them out? The results are quite good and i usually don't touch a running system, however i want to drive deeper and understand what i am doing.
Lucking forward to hear some suggestions!
Hr_kules is offline   Reply With Quote
Boundary conditions for K and Omega in SST model Ryan. SU2 4 July 23, 2021 03:55
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Why do we need to specify k omega on wall surface by using komega sst model Isaiah_HZ OpenFOAM 8 July 1, 2020 10:21
nut, k, omega wall condition with k omega SST giammy92 OpenFOAM Running, Solving & CFD 3 April 3, 2016 11:59
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
