Fixed Temperature vs. fixed heat flux | buoyantCavity case |
February 22, 2023, 05:52 |
Zeinab
Rep Power: 3 |
Hi foamers,
I am working with buoyantSimpleFoam on the buoyant cavity case. I worked out the tutorial with cold and hot walls with temp diff = 19.6 Celsius. Currently, I want to replicate the same case but with fixedGradient BC, i.e., heatFlux in and heat flux out instead of hot and cold walls. Any idea about how should be the value of the gradient to impose? I tried calculating the average gradient on the hot and cold walls from buoyantCavity case, but it wasn't representative at all. Thank you! Regards, Zena |
February 22, 2023, 08:23 |
Nico
Rep Power: 6 |
Hi, i recently started using the same solver and tried the fixedGradient as well as the externalWallheatfluxTemperature BC. The later has the advantage that you choose between flux and power.
Both work fine. If you use the fixedGradient you can get the desired heat flux [w/m^2] by dividing the desired heat flux by the thermal conductivity of the material. For example i wanted to have a heat flux of 1000 w/m^2 so i divided 1000 by 0,607 the thermal conductivity of water at initial temperature and got 1647,44. That value was the fixed gradient. Hope this helps |
February 22, 2023, 09:15 |
Zeinab
Rep Power: 3 |
I got what you say but I still have a question. How to replicate the fixedTemperature case entirely with heatflux / fixedGradient BCs ? In other words how to choose the heat flux in/out value? I tried getting the temperature gradient on the hot and cold walls using OpenFOAM (grad) functionObject, and then took the weighted average of the gradient on each wall using paraview. When I used this gradient as BC in the fixedGradient case, it didn't give the same result. Thank you |
February 22, 2023, 09:18 |
Nico
Rep Power: 6 |
Have you tried wallHeatFlux functionobject? it usually just prints out the heat flux, you can "measure" it and then use it again in a externalWallHeatFluxTemperature BC and check if is the same.
February 22, 2023, 10:16 |
Zeinab
Rep Power: 3 |
I have just tried the walHeatFlux functionObject along with the externalWallHeatFluxTemperature. The results of the fixedGradient case and the externalWallFlux case matched but they didn't match with the original buoyantCavity case of fixedTemperature BC. Is this originally a reasonable comparison? |
strange extreme low radiation heat flux on fixed Temperature surface | fxzf | OpenFOAM Running, Solving & CFD | 0 | March 7, 2018 17:09 |
Wall Heat Flux & Temperature | Greg Perkins | FLUENT | 10 | November 20, 2015 10:32 |
Non-constant heat flux (as a function of wall temperature)) | Laplace | CFX | 1 | February 23, 2014 17:56 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
UDF for heat convection coefficient with fixed surface temperature | Boo85 | Fluent UDF and Scheme Programming | 2 | July 10, 2012 19:43 |
