Pressure on the plate subjected to airflow
Old   February 21, 2023, 12:41
Default Pressure on the plate subjected to airflow
StudentIB is on a distinguished road
I'm analyzing a simple test case of a plate subjected to airflow and trying to obtain a good agreement with an analytical solution of the pressure acting on the plate (the next step is deformation calculation but for that, I need an accurate pressure value). Of course, I assume uniform pressure distribution calculated simply as drag force divided by area. I use this basic formula for drag force: F_D=0.5*rho*C_D*U^2*A where C_D=1.28 (I've found this value for plates, but I'm not sure if it's accurate enough) and A is simply the area of the rectangular surface facing the flow (width of the plate times its height).
The simulation is steady-state, laminar with inlet (2 m/s) and outlet (0 Pa) boundary conditions. I also applied a no-slip wall boundary condition to the walls of the plate. The remaining walls use the default slip wall condition.
Here's the geometry and mesh:
And that's the pressure distribution (already multiplied by the fluid density to have values in Pa) on the surface of the plate facing the flow:
The value obtained from the analytical calculation is 3.072 Pa. As you can see, the simulation shows non-uniform pressure distribution with around 1.5-4.2 Pa in the middle and lower (even reaching negative values) around the edges. What can I do to improve the accuracy and get closer to the analytical solution ? The mesh seems to be dense enough for this type of benchmark analysis but maybe I should keep refining it. So far refinement didn't help (the previous mesh was way more coarse and the results were similar). Or is this kind of pressure distribution normal and I can't get a better agreement with the analytical calculations that assume uniform pressure ?
StudentIB is offline   Reply With Quote
airflow, plate, pressure
Pressure fields in FOAM, p field, total pressure, etc. Tobi OpenFOAM Post-Processing 9 March 25, 2022 02:33
Getting divergence while increasing the back pressure at pressure outlet greenfields15 FLUENT 0 March 19, 2018 00:39
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC Endel OpenFOAM Running, Solving & CFD 3 September 11, 2014 17:29
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
