contactAngle BC in contactAngleCavity tutorial is not working as expected
Old   February 21, 2023, 08:36
Default contactAngle BC in contactAngleCavity tutorial is not working as expected
Iason Tsiapkinis
souvlaki41 is on a distinguished road
Hello everybory,
this is a crosspost from
https://develop.openfoam.com/Develop.../-/issues/2690
Maybe someone can help me here or point me in the right direction? I am trying to figure out, why the contactAngleCavity tutorial is not working as intended.
Summary
In the tutorial case contactAngleCavity, the free surface of a cavity is simulated with the `interfaceTrackingFvMesh` library. In the simulation a contact angle of 70° is set at the walls via the file `0.orig/contactAngle`. The contact angle after running the tutorial, however, is ~80°.
Steps to reproduce
  1. Copy the case `$FOAM_TUTORIALS/incompressible/pimpleFoam/laminar/contactAngleCavity`
  2. Add the following function objects for post-processing (this writes out the first two and last two points on the free surface):
pointHistoryLeft1
        type            pointHistory;
        refHistoryPoint (0 0.01 0);
        fileName        leftPoint.txt;
    pointHistoryLeft2
        type            pointHistory;
        refHistoryPoint (0.00025 0.01 0);
        fileName        leftPointRef.txt;
    pointHistoryRight1
        type            pointHistory;
        refHistoryPoint (0.01 0.01 0);
        fileName        rightPoint.txt;
    pointHistoryRight2
        type            pointHistory;
        refHistoryPoint (0.00975 0.01 0);
        fileName        rightPointRef.txt;
3. Calculate the angle between the first two and the last two points respectively. This can be done by running the accompanied script postProcessing.py inside the simulation directory.
Example case
I attached the tutorial case with slight modifications in the functionObjects, together with the post-processing script.
Run the case using the Allrun script.
[contactAngleCavity.tar]
What is the current *bug* behaviour?
The contact angle at the specified locations is not equal to the set contact angle.
What is the expected *correct* behavior?
The contact angle should be 70°, as specified in `0.orig/contactAngle`.
Relevant logs and/or images
The Figure below shows the calculated angle between the first two and the last two mesh points. Note that the angle does not change with a longer run time. The tutorial runs only for 0.2s.
(contactAngle.png)
Environment information
OpenFOAM version : v2212
Operating system : ubuntu docker container on windows
Possible fixes
The calculations regarding the contact angle can be found in the file
$FOAM_SRC/dynamicFaMesh/interfaceTrackingFvMesh/freeSurfacePointDisplacement.C
in lines 120-197. In this approach, the vector N is rotated by the value of contactAngle at the specified boundaries. The patchMirrorPoints at this boundary are then moved using (line 225f.):
patchMirrorPoints[patchI] =
            peCentres + ((I - 2*N*N)&delta);
Maybe the innermost controlPoints have to be moved as well to satisfy the contact angle.
souvlaki41 is offline   Reply With Quote
Old   March 21, 2023, 07:23
Iason Tsiapkinis
Any ideas or tips?
contactangle, dynamicfvmesh, dynamicmesh, multiphase, tutorial
[Virtualization] OpenFOAM oriented tutorial on using VMware Player - support thread wyldckat OpenFOAM Installation 2 July 11, 2012 17:01
How to install CGNS under windows xp? lzgwhy Main CFD Forum 1 January 11, 2011 19:44
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
FoamToEnsight/EnsightParts/VTK not working with motorbike tutorial madad2005 OpenFOAM Bugs 5 October 18, 2009 05:48
