February 21, 2023, 02:17 |
2D Axisymmetric - buoyantFoam
Khan
Rep Power: 8 |
My case is with the transient solver for buoyant, turbulent flow of incompressible fluids (i.e. water) by use of buoyantFoam. The idea here is to mimic the temperature transients of the sensible stratified heat storage tank with one inlet-outlet configuration.
I could manage to have a (not verified) solution for a 3D simulation, see: https://youtu.be/VYZ0ZFjI1lE In order to reduce the computational cost, I would like to apply a 2D Axisymmetric solution for the same geometry. Then I had difficulties with the issue that the temperature degrees go beyond the physical range defined (internal volume at 25 deg-C at the initial condition with an inlet of 55 deg-C at the boundary condition) with a FOAM FATAL ERROR: Code:
--> FOAM FATAL ERROR: Maximum number of iterations exceeded: 100 - gmsh geo file i. export the mesh as msh (version 2) ii. gmshToFoam iii. use the boundary below - openfoam files required (0, Constant, and System) Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // 7 ( outlet { type patch; physicalType patch; nFaces 2; startFace 1831; } wedge_1 { type wedge; physicalType wedge; nFaces 978; startFace 1833; } wedge_2 { type wedge; physicalType wedge; nFaces 978; startFace 2811; } diffuser { type empty; physicalType empty; nFaces 78; startFace 3789; } inlet { type patch; physicalType patch; nFaces 2; startFace 3867; } walls { type wall; physicalType wall; nFaces 84; startFace 3869; } defaultFaces { type empty; nFaces 22; startFace 3953; } ) // ************************************************************************* // |
axisymmetric, buoyant flows, gmsh cylinder |
Error with the calculation of boundary cell face area magnitude in axisymmetric solve | Danny_cfd | Fluent UDF and Scheme Programming | 3 | May 11, 2021 04:10 |
Is ignoring the Uz component in axisymmetric simulations safe? | hconel | OpenFOAM Running, Solving & CFD | 0 | December 12, 2020 08:23 |
Velocity Cell Macros in 2D Axisymmetric Swirl | c_023 | Fluent UDF and Scheme Programming | 1 | February 14, 2020 11:37 |
Difference between Axisymmetric and Symmetric Boundary condition | AS_Aero | FLUENT | 1 | January 25, 2019 10:51 |
Axisymmetric Boundary condition | Mohit Singh | SU2 | 3 | July 15, 2015 10:19 |
