OpenFOAM solution falling apart in the PimpleFOAM solver |
February 20, 2023, 02:46 |
Dmitry
Rep Power: 8 |
Hello everyone! An error occurs while solving the problem.
Task in the movement of air in the sinuses. Time step 5e-7, Courant number <1. The solution is stable until 0.025 seconds, after which the Courant number decreases and the solution falls apart. Flow velocity 1 m/s, supersonic areas appear at the exit (which is very strange). Mesh quality log here: Code:
Create time Create mesh for time = 0 Time = 0 Mesh stats points: 5401673 faces: 14022342 internal faces: 12965953 cells: 4389800 faces per cell: 6.147955 boundary patches: 3 point zones: 1 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 3710992 prisms: 120467 wedges: 0 pyramids: 0 tet wedges: 381 tetrahedra: 1 polyhedra: 557959 Breakdown of polyhedra by number of faces: faces number of cells 4 141179 5 106526 6 88992 7 13 8 14 9 110298 10 2 11 4 12 61431 14 5 15 44639 17 2 18 4854 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces PointsSurface topology inlet 7393 7893 ok (non-closed singly connected) outlet 5251 6139 ok (non-closed singly connected) nose 1043745 1205189 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking basic pointZone addressing... PointZone PointsBoundingBox frozenPoints 0(1e+150 1e+150 1e+150) (-1e+150 -1e+150 -1e+150) Checking geometry... Overall domain bounding box (-0.06548677 -0.06728039 -0.02183478) (0.03593177 0.03602325 0.02079412) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (3.222643e-16 1.024171e-15 -4.319472e-17) OK. Max cell openness = 4.320483e-16 OK. Max aspect ratio = 3.730799 OK. Minimum face area = 2.814233e-09. Maximum face area = 4.129001e-06. Face area magnitudes OK. Min volume = 4.700838e-13. Max volume = 8.307965e-09. Total volume = 3.295746e-05. Cell volumes OK. Mesh non-orthogonality Max: 63.17777 average: 12.60157 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.252324 OK. Coupled point location match (average 0) OK. Mesh OK. End Last edited by KAYANO; February 20, 2023 at 07:01. |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Sharing links for two phase solver packages developed by openfoam community | swap_9068 | OpenFOAM Programming & Development | 1 | April 2, 2017 06:43 |
Modified pimpleFoam solver to MRFPimpleFoam solver | hiuluom | OpenFOAM Programming & Development | 12 | June 14, 2015 22:22 |
smoothSolver diverges - solution in using PBiCG solver? | makaveli_lcf | OpenFOAM Running, Solving & CFD | 3 | September 11, 2013 13:44 |
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon | qinmaple | OpenFOAM Announcements from Other Sources | 4 | August 10, 2012 12:00 |
