Handling underdetermined cells
Old   February 17, 2023, 06:50
Default Handling underdetermined cells
Nico
Hr_kules is on a distinguished road
Hi, i checked the mesh of my recent simulation and saw that the first few layers of my prism layer are all underdetermined. The first ~5 layers are affected. Is there a way to handle this numerically? I suppose i need a +y of ~1 what the mesh achieves, however results at the wall are not physically reliable.
Thanks in andvance!
Checking geometry...
    Overall domain bounding box (-0.025 -0.025 0) (0.025 0.025 1)
    Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
    Mesh has 3 solution (non-empty) directions (1 1 1)
    Boundary openness (7.67334e-17 -3.10779e-15 -7.99046e-17) OK.
    Max cell openness = 1.7394e-15 OK.
    Max aspect ratio = 50.1398 OK.
    Minimum face area = 2.45594e-08. Maximum face area = 2.29773e-06.  Face area magnitudes OK.
    Min volume = 5.07227e-11. Max volume = 1.41971e-09.  Total volume = 0.00196126.  Cell volumes OK.
    Mesh non-orthogonality Max: 36.2104 average: 4.87132
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.501603 OK.
    Coupled point location match (average 0) OK.
    Face tets OK.
    Min/max edge length = 2.21057e-05 0.00206631 OK.
    All angles in faces OK.
    Face flatness (1 = flat, 0 = butterfly) : min = 0.999995  average = 1
    All face flatness OK.
    Cell determinant (wellposedness) : minimum: 7.91759e-05 average: 3.68076
 ***Cells with small determinant (< 0.001) found, number of cells: 137256
  <<Writing 137256 under-determined cells to set underdeterminedCells
    Concave cell check OK.
    Face interpolation weight : minimum: 0.3453 average: 0.49016
    Face interpolation weight check OK.
    Face volume ratio : minimum: 0.503308 average: 0.957595
    Face volume ratio check OK.
Failed 1 mesh checks.
End
Hr_kules is offline   Reply With Quote
cellZone not taking all the cells inside rahulksoni OpenFOAM Running, Solving & CFD 6 January 25, 2019 01:11
snappyHexMesh in parallel - FOAM Fatal IO Error mturcios777 OpenFOAM Running, Solving & CFD 4 August 10, 2012 20:18
[ICEM] error analysis despaired student ANSYS Meshing & Geometry 7 June 27, 2012 12:57
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
