CL is so high
Old   February 16, 2023, 16:00
Question CL is so high
Eduardo Ireta
ireta is on a distinguished road
Hi, i new in OpenFoam, I try to make a simulation to get the cl of a plane but i have 3 problems:
1.-The principal problem is for the cl is so high, I'm trying to make a comparison with several CFD programs (fluent, xflr5, OpenFoam) and the cl is like to 0.28, but in OpenFoam i got 3.3. I donīt know what is the problem, i change several values like Aref, Umag, etc..
2.-The simulation never converges, I end up truncating the simulation at time 500 or 1000 for get the values.
3.-When I visualize the results in openfoam and the end of the control volume the speed rises very quickly until it reaches 30 m/s. If I increase the size of the control volume in that direction, the speed continues to increase.
I would like to know what my faults are so I can learn more about openfoam.
This is the directory link
https://drive.google.com/drive/folde...jj?usp=sharing
ireta is offline   Reply With Quote
Old   February 17, 2023, 14:42
Tobermory will become famous soon enough
Point 1 (bad CL prediction) is probably lined to / the result of point 2 (poor convergence), as is 3 (unphysicak results).
Taking a brief look at your model - forgive me for saying, but your mesh is awful. Your mesh refinement zone seems to have missed your geometry, and the resolution at the outlet is probably too coarse - see the attached. My advice is to start by getting a better mesh.
If the case still falls then we'll need to look at the BC's ... I didn't open them. But start with the mesh. Good luck!
Tobermory is offline   Reply With Quote
aerodynamic, cfd, coefficient of lift, converge cfd, openfoam
BC for Actuator Disk - Flow Vel from High Pressure to Low Pressure vinguva OpenFOAM Running, Solving & CFD 2 March 8, 2016 00:46
High Lift Airfoils At High Angles Of Attack Luiz Pancini FLUENT 2 April 9, 2015 09:01
flow with high turbulent viscosity ratio Phillips Main CFD Forum 2 August 25, 2008 19:01
flow with high turbulent viscosity ratio Phillips FLUENT 0 August 24, 2008 19:01
whether DEM or Eulerian approach for high solidup CFDUSERIN Main CFD Forum 0 April 19, 2007 06:35
