OpenFOAM Solver - Sensible Stratified Storage
Old   February 14, 2023, 00:05
Default OpenFOAM Solver - Sensible Stratified Storage
Khan
HumanistEngineer is on a distinguished road
Dear All,
I am new to OpenFOAM.
In my case, I need to analyze various design parameters for a sensible stratified heat storage tank, its medium being water with one inlet-outlet formation (i.e. there is an inlet velocity) (see the picture below) .
If I understand correctly, I need to use the OpenFOAM solver "buoyantBoussinesqPimpleFoam" in order to have a transient solution for the buoyant, turbulent flow of incompressible fluids to mimic the temperature change through the storage unit in time. Correct me if I am wrong, please.
Since I am a newbie, I need to base on a ready OpenFOAM tutorial. Which tutorial (from OpenFOAM tutorials, YouTube videos, blog page etc.) shall I base for my case? Would you please share?
Kind Regards.
Hakan
HumanistEngineer is offline   Reply With Quote
Old   February 15, 2023, 09:59
Khan
Would you please check the attached OpenFOAM files as to simulate temperature transients of a stratified sensible heat storage tank?
I based on the OpenFoam tutorial "hotRoom" and made changes accordingly (I am newbie). But I have some weird results.
Old   February 16, 2023, 00:08
Khan
For the simulation result that I expect you can see my first animation video via: YouTube Video
The animation is for the charging case of the sensible stratified heat storage tank (inlet velocity at 2 m/s from the top inlet). The medium temperature is at 25 °C at the initial condition while the top inlet has an inflow at the temperature of 55 °C.
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 16:44
OpenFOAM webinar: A multidimensional parallel numerical solver of ADM1 model for anae Gavin OpenFOAM Announcements from Other Sources 0 July 12, 2018 11:30
Memory protection in OpenFOAM / combinig with FORTRAN botp OpenFOAM Programming & Development 2 February 15, 2016 13:25
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 cfd.direct OpenFOAM Announcements from Other Sources 2 August 31, 2015 14:36
