sourceterm in EPSILON equation
Old   February 10, 2023, 05:22
Default sourceterm in EPSILON equation
Lil
Lila
Lil is on a distinguished road
Can anyone please tell me what is the source term (epsilonSource()) in epsilon equ stands for? ANd how is it calculated ?
// Dissipation equation
tmp<fvScalarMatrix> epsEqn
fvm::ddt(alpha, rho, epsilon_)
+ fvm::div(alphaRhoPhi, epsilon_)
- fvm::laplacian(alpha*rho*DepsilonEff(), epsilon_)
C1_*alpha()*rho()*GbyNu*Cmu_*k_()
- fvm::SuSp(((2.0/3.0)*C1_ - C3_)*alpha()*rho()*divU, epsilon_)
- fvm::Sp(C2_*alpha()*rho()*epsilon_()/k_(), epsilon_)
+ epsilonSource()
+ fvOptions(alpha, rho, epsilon_)
Thank you
Lil is offline   Reply With Quote
Old   February 11, 2023, 21:14
s1291's Avatar
s1291 is on a distinguished road
Someone can correct me if I am wrong, but I think this is used to add source terms to equations via scalarCodedSource (or vectorCodedSource) in the fvOptions file.
Here is an example with some comments:
codedSource
    type            scalarCodedSource;
    selectionMode   all;
    fields          (epsilon); // You need to specify the field here, e.g. epsilon, k, etc.
    name            my_source;
    codeAddSup
        scalarField& mySource = eqn.source(); // <<<<<<<  you have a reference to epsilonSource (or wharever field you've specified above)
        // Retrieve the cell centres
        const scalarField& cells = mesh_.C();
        // iterate over the cells to assign the source term
        // Apply the source
        forAll(cells, i)
            // cell volume specific source
            mySource[i] += 42; // add the expressions here
"When in doubt, use brute force." -- Ken Thompson
s1291 is offline   Reply With Quote
Old   February 19, 2023, 06:53
shinji nakagawa
snak is on a distinguished road
You can search functions at the extended code guide site.
https://www.openfoam.com/documentati...des/v2112/doc/
If you search epsilonSource, you will find each kEpsilon models have its own epsilonSource function.
for instance, a epsilonSource function in a standard kEpsilon model is shown in the following link:
https://www.openfoam.com/documentati...ce.html#l00069
You can use the search function at source code repositories too.
https://develop.openfoam.com/search?...ory_ref=master
snak is offline   Reply With Quote
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Long output in terminal. ssa_cfd OpenFOAM Running, Solving & CFD 1 March 18, 2019 06:25
epsilon and K blowing up. sivakumar OpenFOAM Running, Solving & CFD 1 October 25, 2012 05:50
value of k and epsilon in N-S equation smith FLUENT 0 September 9, 2007 06:51
bouyancy term in epsilon equation Michael Main CFD Forum 1 June 25, 1999 11:20
