How to mark the fluids from different inlets in interFoam
Old   February 9, 2023, 02:44
Smile How to mark the fluids from different inlets in interFoam
Jarvis
nbyjn is on a distinguished road
Hello foamers,
As shown in the attachment, if there is a cube cavity with air inside, and there are four inlets at the top of the cube. Then the four inlets begin to inject the same kind of liquid (e.g. water) into the cavity.
How can I mark the inlet information easily? That is, the water injected into inlet1 is marked as 1 (or anything else), the water injected into inlet2 is marked as 2, and so on. (No need to consider the mixing of liquids, just simulate a short period of time and stop before mixing)
Can this be accomplished by scalartransport object?(maybe more than four inlets)
Thank you for any advise!
nbyjn is offline   Reply With Quote
Old   February 9, 2023, 03:08
yeharav is on a distinguished road
I think the scalar transport function object is a good start.
look here :
OpenFoam - concentration - variable for specie
yeharav is offline   Reply With Quote
Old   February 9, 2023, 03:17
Jarvis
look here :
Hi yeharav, thank you so much! I will try the scalartransport function.
I have another question: are there any limits to the value of scalartransport function? Can I set the initial value of the four inlets as 1,2,3 and 4?
Looking forward to your reply!
Old   February 9, 2023, 04:42
I never tried, but I think it should. Don't forget to add to field name like so
functions
scalar1
type scalarTransport;
libs (solverFunctionObjects);
resetOnStartUp no;
region cabin;
field H2O;
fvOptions
See https://github.com/OpenFOAM/OpenFOAM...larTransport.H
or any documentation for details.
Dissimilar fluids for two separate inlets in compressible flow modeling Zahid123 SU2 1 September 1, 2022 13:04
interFoam with different gas and liquid inlets phani45 OpenFOAM Running, Solving & CFD 0 May 1, 2017 13:51
k-e & GAMG interFoam Schemitisation Stability Issue JFM OpenFOAM Running, Solving & CFD 3 December 1, 2015 06:58
Input 2 inlets with different fluids keby9 FLUENT 0 December 7, 2012 09:30
two inlets with two different fluids discovolante Main CFD Forum 1 April 13, 2009 09:27
