February 4, 2023, 15:51 |
How to combine (merge?) meshes
Alan w
Rep Power: 6 |
My question concerns the functionality of snappyHexMesh, but with a twist.
I modelled a wheel in Salome, and have imported it into OpenFoam via a unv file. When I use ideasUnvToFoam on that file, I get a polyMesh that defines the tire. Now, I need to create a domain for it. If I use blockMesh, is it not true that I will get a polyMesh, which will overwrite the one previously created with ideasUnvToFoam? Note that I don't have an stl file for the wheel which would ordinarily be used by snappyHexMesh. There are other cases with rotating and non-rotating MRF zones, which are dealt with by using mergeMeshes, but these are set up for adjacent meshes, whereas in my case, if I merged the domain and the wheel, the meshes would overlap. Not what is needed. How to deal with this? |
February 6, 2023, 04:40 |
Yann
Rep Power: 29 |
Hello Alan,
What is the geometry in your unv file? A surface mesh of the wheel ? A volume mesh of the inside of the wheel ? Or a volume mesh of the outside of the wheel ? Regards, Yann |
February 6, 2023, 13:58 |
Solved! Using foamToSurface
Alan w
Rep Power: 6 |
Hi Yann!
My query was in regard to the use of snappyHexMesh to cut a body, using a .unv file as input for the body, and blockMesh to create the domain. The .unv file was of a wheel, fully meshed in Salome. I had no idea of how to do it, but I discovered an answer soon after I posted my query. So I'm sorry to trouble people with a query that was quickly overtaken by events, but it often seems that if I don't post a query, I usually spend inordinate amounts of time groping for an answer. Somehow this reminds me of quantum theory. Anyway, using a temporary case folder for the body, I ran ideasUnvToFoam to get a polyyMesh, and then foamToSurface (this was the key), which created an stl file of the body, in this case the wheel. Then I copied the stl file to the primary case folder in which I ran blockMesh, and then snappyHexMesh. So thank you for your response, and don't go away, for it is inevitable that I will again myself completely stumped. |
[mesh manipulation] How to combine intersecting complex meshes? | BrandonS | OpenFOAM Meshing & Mesh Conversion | 1 | June 25, 2020 22:30 |
[ICEM] merge meshes between hexa and prism | jjz2013 | ANSYS Meshing & Geometry | 39 | February 12, 2019 11:38 |
Merge Meshes in parallel | DominicTNC | OpenFOAM | 0 | September 4, 2017 23:39 |
[ICEM] Smoothing before merge meshes | FJSJ | ANSYS Meshing & Geometry | 0 | May 20, 2013 12:30 |
Merge 2 unstructured meshes | vinc | ANSYS Meshing & Geometry | 0 | May 19, 2011 17:14 |
