'Signal: Segmentation fault (11)' while running openFoam in Parallel Processing |
Jaymeen Patel
Rep Power: 3 ![]() |
I am new to openFoam and running a case to learn parallel processing in openFoam.
After decomposePar, it devide the problem amongst the processors. then when the command: mpirun -np 4 icoFoam -parallel > log & is applying it does not run the problem and gives error as per log file. thanks in advance log file: [ravi:334317] *** Process received signal *** [ravi:334317] Signal: Segmentation fault (11) [ravi:334317] Signal code: Address not mapped (1) [ravi:334317] Failing at address: (nil) [ravi:334317] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7fbdaff98090] [ravi:334317] [ 1] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_ess_singleton.so(+0x319b)[0x7fbdade8019b] [ravi:334317] [ 2] /usr/lib/x86_64-linux-gnu/libopen-rte.so.20(orte_init+0x22e)[0x7fbdaedc91de] [ravi:334317] [ 3] /usr/lib/x86_64-linux-gnu/libmpi.so.20(ompi_mpi_init+0x30e)[0x7fbdaf08427e] [ravi:334317] [ 4] /usr/lib/x86_64-linux-gnu/libmpi.so.20(PMPI_Init_thread+0x45)[0x7fbdaf0a5405] [ravi:334317] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x2c)[0x7fbdafd48b3c] [ravi:334317] [ 6] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x8df)[0x7fbdb0762e1f] [ravi:334317] [ 7] icoFoam(+0x22c25)[0x5579b7a3cc25] [ravi:334317] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7fbdaff79083] [ravi:334317] [ 9] icoFoam(+0x25c1a)[0x5579b7a3fc1a] [ravi:334317] *** End of error message *** [ravi:334318] *** Process received signal *** [ravi:334318] Signal: Segmentation fault (11) [ravi:334318] Signal code: Address not mapped (1) [ravi:334318] Failing at address: (nil) [ravi:334318] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f4fe92a9090] [ravi:334318] [ 1] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_ess_singleton.so(+0x319b)[0x7f4fe719119b] [ravi:334318] [ 2] /usr/lib/x86_64-linux-gnu/libopen-rte.so.20(orte_init+0x22e)[0x7f4fe80da1de] [ravi:334318] [ 3] /usr/lib/x86_64-linux-gnu/libmpi.so.20(ompi_mpi_init+0x30e)[0x7f4fe839527e] [ravi:334318] [ 4] /usr/lib/x86_64-linux-gnu/libmpi.so.20(PMPI_Init_thread+0x45)[0x7f4fe83b6405] [ravi:334318] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x2c)[0x7f4fe9059b3c] [ravi:334318] [ 6] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x8df)[0x7f4fe9a73e1f] [ravi:334318] [ 7] icoFoam(+0x22c25)[0x56223badec25] [ravi:334318] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f4fe928a083] [ravi:334318] [ 9] icoFoam(+0x25c1a)[0x56223bae1c1a] [ravi:334318] *** End of error message *** [ravi:334316] *** Process received signal *** [ravi:334316] Signal: Segmentation fault (11) [ravi:334316] Signal code: Address not mapped (1) [ravi:334316] Failing at address: (nil) [ravi:334316] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7f207227f090] [ravi:334316] [ 1] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_ess_singleton.so(+0x319b)[0x7f207016719b] [ravi:334316] [ 2] /usr/lib/x86_64-linux-gnu/libopen-rte.so.20(orte_init+0x22e)[0x7f20710b01de] [ravi:334316] [ 3] /usr/lib/x86_64-linux-gnu/libmpi.so.20(ompi_mpi_init+0x30e)[0x7f207136b27e] [ravi:334316] [ 4] /usr/lib/x86_64-linux-gnu/libmpi.so.20(PMPI_Init_thread+0x45)[0x7f207138c405] [ravi:334316] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x2c)[0x7f207202fb3c] [ravi:334316] [ 6] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x8df)[0x7f2072a49e1f] [ravi:334316] [ 7] icoFoam(+0x22c25)[0x55d648021c25] [ravi:334316] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7f2072260083] [ravi:334316] [ 9] icoFoam(+0x25c1a)[0x55d648024c1a] [ravi:334316] *** End of error message *** [ravi:334319] *** Process received signal *** [ravi:334319] Signal: Segmentation fault (11) [ravi:334319] Signal code: Address not mapped (1) [ravi:334319] Failing at address: (nil) [ravi:334319] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x43090)[0x7eff2ce47090] [ravi:334319] [ 1] /usr/lib/x86_64-linux-gnu/openmpi/lib/openmpi/mca_ess_singleton.so(+0x319b)[0x7eff2ad2f19b] [ravi:334319] [ 2] /usr/lib/x86_64-linux-gnu/libopen-rte.so.20(orte_init+0x22e)[0x7eff2bc781de] [ravi:334319] [ 3] /usr/lib/x86_64-linux-gnu/libmpi.so.20(ompi_mpi_init+0x30e)[0x7eff2bf3327e] [ravi:334319] [ 4] /usr/lib/x86_64-linux-gnu/libmpi.so.20(PMPI_Init_thread+0x45)[0x7eff2bf54405] [ravi:334319] [ 5] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/openmpi-system/libPstream.so(_ZN4Foam8UPstream4initERiRPPcb+0x2c)[0x7eff2cbf7b3c] [ravi:334319] [ 6] /opt/openfoam9/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam7argListC1ERiRPPcbbb+0x8df)[0x7eff2d611e1f] [ravi:334319] [ 7] icoFoam(+0x22c25)[0x562cb3ebcc25] [ravi:334319] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x7eff2ce28083] [ravi:334319] [ 9] icoFoam(+0x25c1a)[0x562cb3ebfc1a] [ravi:334319] *** End of error message *** ================================================== ================================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = RANK 0 PID 334316 RUNNING AT ravi = KILLED BY SIGNAL: 11 (Segmentation fault) ================================================== ================================= ================================================== ================================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = RANK 1 PID 334317 RUNNING AT ravi = KILLED BY SIGNAL: 11 (Segmentation fault) ================================================== ================================= ================================================== ================================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = RANK 2 PID 334318 RUNNING AT ravi = KILLED BY SIGNAL: 11 (Segmentation fault) ================================================== ================================= ================================================== ================================= = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES = RANK 3 PID 334319 RUNNING AT ravi = KILLED BY SIGNAL: 11 (Segmentation fault) ================================================== ================================= |
Farzad Faraji
Rep Power: 7 ![]() |
Dear Jaymeen
Did you find out why this error happens? Thanks, Farzad |
openfoam 9., parallel processing, segmentation fault: 11 |
mpirun problems: exited on signal 11 (segmentation fault) | vaina74 | OpenFOAM Running, Solving & CFD | 17 | March 30, 2023 12:53 |
Parallelization of a self-compiled boundary condition | dalasrevo | OpenFOAM Programming & Development | 4 | August 2, 2022 14:16 |
Foam-Extend 4.1 Mpi doesn't exit gracefully at the end of parallel run | EternalSeekerX | OpenFOAM Running, Solving & CFD | 0 | May 30, 2021 03:04 |
segmentation fault - parallel running | CrisMoreira | OpenFOAM Running, Solving & CFD | 13 | November 1, 2015 16:13 |
'Segmentation fault: 11' on running application in parallel | ulfaslak | OpenFOAM Running, Solving & CFD | 2 | November 27, 2013 07:57 |
