January 31, 2023, 07:14 |
FOAM FATAL IO ERROR:file: unknown
Yateng Qiao
Rep Power: 3 |
Hi everyone,
I use the dynamic mesh according to the propeller tut. When I use the command: decomposePar. The processor folder does not contain 0 folder.(I use ICEM mesh converted by fluentMeshtoFoam) There is an error list as follows: Create time Decomposing mesh region0 Reading "decomposeParDict" Create mesh Calculating distribution of cells Selecting decompositionMethod hierarchical Finished decomposition in 0.89 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 204363 Number of faces shared with processor 1 = 14384 Number of processor patches = 1 Number of processor faces = 14384 Number of boundary faces = 19174 Processor 1 Number of cells = 204363 Number of faces shared with processor 0 = 14384 Number of faces shared with processor 2 = 14224 Number of processor patches = 2 Number of processor faces = 28608 Number of boundary faces = 4952 Processor 2 Number of cells = 204363 Number of faces shared with processor 1 = 14224 Number of faces shared with processor 3 = 13379 Number of processor patches = 2 Number of processor faces = 27603 Number of boundary faces = 6687 Processor 3 Number of cells = 204363 Number of faces shared with processor 2 = 13379 Number of faces shared with processor 4 = 14264 Number of processor patches = 2 Number of processor faces = 27643 Number of boundary faces = 8107 Processor 4 Number of cells = 204363 Number of faces shared with processor 3 = 14264 Number of faces shared with processor 5 = 14376 Number of processor patches = 2 Number of processor faces = 28640 Number of boundary faces = 4908 Processor 5 Number of cells = 204363 Number of faces shared with processor 4 = 14376 Number of faces shared with processor 6 = 14223 Number of processor patches = 2 Number of processor faces = 28599 Number of boundary faces = 5137 Processor 6 Number of cells = 204363 Number of faces shared with processor 5 = 14223 Number of faces shared with processor 7 = 14384 Number of processor patches = 2 Number of processor faces = 28607 Number of boundary faces = 4953 Processor 7 Number of cells = 204369 Number of faces shared with processor 6 = 14384 Number of processor patches = 1 Number of processor faces = 14384 Number of boundary faces = 19174 Number of processor faces = 99234 Max number of cells = 204369 (0.00256895% above average 204364) Max number of processor patches = 2 (14.2857% above average 1.75) Max number of faces between processors = 28640 (15.4443% above average 24808.5) Time = 0 --> FOAM FATAL IO ERROR: file: unknown I cant find where the problem is. |
[mesh manipulation] RefineMesh Error and Foam warning | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 4 | March 3, 2018 11:32 |
error with reactingFoam | BakedAlmonds | OpenFOAM Running, Solving & CFD | 4 | June 22, 2016 02:21 |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 04:14 |
decomposePar is missing a library | whk1992 | OpenFOAM Pre-Processing | 8 | March 7, 2015 07:53 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
