setting up three-phase icoReactingMultiphaseInterFoam |
January 29, 2023, 05:15 |
California
Rep Power: 3 |
I am using a variant of the v2006 icoReactingMultiphaseInterFoam solver, called thermocapillaryInterFoam/lpbfFoam, made by someone named patrick zimbrod. Patrick's Github: https://github.com/pzimbrod Solver link: https://zenodo.org/badge/latestdoi/368456876 The variant adds surface tension and marangoni force. I would like to simlulate both the melting and evaporation of powdered metal but, being new to OpenFOAM, I am at a loss as to how to set up evaporation. Another question I have is whether or not this model has condensation. I have read from other threads that this is not the case, so I would also like to ask if someone has any clue where to start. The zip attached is the base case that he provided, it uses yade to setup the model, as the solver is designed to study laser powder bed. The case itself does not have a gas phase, and I do not know how to add it in. Thanks. |
May 28, 2023, 22:26 |
#2 | |
Qiuxian Zhong
Rep Power: 4 |
Did you achieve the addition of the gas phase, please? |
condensation, evaporation, gas phase, lpbf, three phase |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Setting up a Two Phase One Component Porous Media Case | adilch | OpenFOAM Running, Solving & CFD | 0 | July 11, 2013 09:40 |
Residual level setting of Fluent | lhlh | ANSYS | 2 | November 17, 2012 21:35 |
two Phase column simulation | chemeng | OpenFOAM | 3 | August 18, 2010 12:53 |
