interFoam crashing and showing unexpected results.
Old   January 25, 2023, 13:34
Default interFoam crashing and showing unexpected results.
SamGee Gamwise
samgee is on a distinguished road
I am trying to create a simulation of a pool with an inlet, drain, and atmosphere. I am curious to see how long the water takes to mix.
I've set up my geometry through Salome, then converted the UNV files to a foam polyMesh.
I set up the simulation using the waterChannel tutorial example from the v10 org version. It ran but showed strange results and crashed after not very long:
https://i.imgur.com/WUolPyN.gifv
I have also tried using the same tutorial case and the esi version but got stuck here with "No NRF models found":
My case is here: https://drive.google.com/file/d/1aZQ...ew?usp=sharing
Any help would be greatly appreciated!
samgee is offline   Reply With Quote
interfoam, multiphase
