LES DeardorffDiffStress
Old   January 25, 2023, 03:07
Default LES DeardorffDiffStress
Tom-Robin Teschner
t.teschner is on a distinguished road
I am trying to get the DeardorffDiffStress model to work and can't seem to get the compressbile version to run. Running the model in incompressible mode works just fine, but when switching to compressible flow, I am getting the following error:
Incompatible dimensions for operation
    [R[1 -1 -3 0 0 0 0] ] - [R[0 2 -3 0 0 0 0] ]
Makes sort of sense, I am using
[0 2 -2 0 0 0 0]
as my dimensions when setting up the incompressible version for the Reynolds stresses, so multiplying by density should then remove this issue, so setting R to
[1 -1 -2 0 0 0 0]
then results in this error:
--> FOAM FATAL ERROR: (openfoam-2212)
Different dimensions for '(a = b)'
     dimensions : [0 2 -1 0 0 0 0] != [0.5 0.5 -1 0 0 0 0]
    From bool Foam::checkDims(const char*, const Foam::dimensionSet&, const Foam::dimensionSet&)
    in file dimensionSet/dimensionSet.C at line 56.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#1  Foam::error::simpleExit(int, bool) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#2  Foam::error::exiting(int, bool) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#3  Foam::dimensionSet::operator=(Foam::dimensionSet const&) const in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so
#4  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::operator=(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam
#5  Foam::LESModels::DeardorffDiffStress<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correctNut() in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so
#6  ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam
#7  __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#8  ? in /usr/lib/openfoam/openfoam2212/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam
So at least I know the issue is in correctNut() but that does not really help. The solver does not start (i.e. no momentum equation is solved, it crashes before then, so probably the issue is happening once the laplacian term is evaluating the viscosity), just wondering where these dimensions of
do come from. The first set seems to be something of a kinematic viscosity, but no idea where the second one is comming from (or what operation is producing kg^0.5 * m^0.5 s^-1 ... seems to be equivalent of sqrt(R)).
Any idea what to change to get this to work for compressible flows?
t.teschner is offline   Reply With Quote
deardorff, deardorffdiffstress, openfoam, reynolds stresses
Meshing for LES of Ahmed Body saintandsinnerz STAR-CCM+ 0 February 9, 2021 13:12
Grid difference between wall modeled LES and wall resolved LES hityangsir Main CFD Forum 9 April 17, 2015 12:59
OpenFOAM LES capability questions siw OpenFOAM Running, Solving & CFD 3 January 6, 2015 09:50
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
