Sowfa ABL solver wind direction change question. |
January 25, 2023, 01:29 |
Hi I am currently running NREL'S SOWFA to get the precursodr data for ALM solver.
I followed the instruction on link below https://github.com/NREL/SOWFA/issues...ment-423210461 Only differecnes from the instrucitons are wind direction change (from west(270 deg) to northwest(315 deg)) and time step ( 1000 to 2000 to just check whether it works) . But in the third step of the instruction "3. Continue/restart your simulation from 20000 to 22000 step", an error occurs and can't proceed from here. Attached files are controlDict, boundaryDataPre, and setUp file of example case and log file of the "runscript.solve.1" Thank you |
Boundary conditions for wind from variable direction | michael3000 | OpenFOAM Running, Solving & CFD | 4 | March 7, 2023 05:30 |
How to give wind direction? | Kim yongchul | FLUENT | 0 | October 1, 2020 16:51 |
A simple question about time step with wind turbine simulation | Joao Bomfim | Main CFD Forum | 2 | October 18, 2019 09:56 |
How to change flow direction during a transient analysis? | kaufparkangucker | Fluent UDF and Scheme Programming | 9 | June 22, 2017 21:29 |
How to change the thermophysical model in a solver? | hangs | OpenFOAM Programming & Development | 0 | November 9, 2016 22:20 |
