Sowfa ABL solver wind direction change question. |
January 25, 2023, 01:23 |
Hi , I am currently running SOWFA to get the turbine outputs of single turbine in the stable flat terrain environment.
I slightly adjusted the setUp file of the original example case "example.ABL.flatterrain.stable" to change the wind drection from west(270 deg) to north west(315 deg). I followed the instruction on link below and got error at the third step. https://github.com/NREL/SOWFA/issues...ment-423210461 Here are the log file of the "runscript.solve.1" and specific contents of controlDict, setUp and boundaryDataPre. |
Boundary conditions for wind from variable direction | michael3000 | OpenFOAM Running, Solving & CFD | 4 | March 7, 2023 05:30 |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 06:02 |
A simple question about time step with wind turbine simulation | Joao Bomfim | Main CFD Forum | 2 | October 18, 2019 09:56 |
How to change flow direction during a transient analysis? | kaufparkangucker | Fluent UDF and Scheme Programming | 9 | June 22, 2017 21:29 |
thermal phase change question | CFDflying | CFX | 1 | February 18, 2004 05:10 |
