AMR on pointDisplacement field - OpenFoam v10
Old   January 24, 2023, 11:23
Default AMR on pointDisplacement field - OpenFoam v10
npb
npb is on a distinguished road
Hello!
Do you know how can the dynamic mesh refiement (AMR) be applied on pointDisplacement field or in a certain defined distance from the moving object?
I know that the field, on which the refinement is applied on, should be scalarField, but what should be this field as the need of refinement comes from the large displacement?
(I use OpenFoam v10 if this is important.)
Thank you!
npb is offline   Reply With Quote
Frequently Asked Questions about Installing OpenFOAM wyldckat OpenFOAM Installation 3 November 14, 2023 12:58
[Other] dynamicTopoFVMesh and pointDisplacement RandomUser OpenFOAM Meshing & Mesh Conversion 6 April 26, 2018 08:30
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 07:55
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
