January 23, 2023, 14:56 |
Mapped boundary condition implementation
Alessandro Spreafico
Rep Power: 3 |
Dear Foamers,
I've recently struggled to implement a mapped boundary condition on a backward facing step geometry in order to achieve a fully developed turbulent flow. In particular, I tried to map the velocity field at the inlet from a plane at a fixed distance downstream. Briefly, the simulation is intended to be a simple conjugated heat transfer problem in which the fluid domain is thermally coupled with the solid domain. The solid domain is composed by the lower wall (internally heated) and the step wall (not heated), whereas the working fluid is liquid sodium (cf. attached image). I used "topoSet" and "splitMeshRegions" to create the three regions, namely Fluid, ColdWall and Hotwall. To implement the the fluid velocity inlet boundary condition, I first edited the constant/polymesh/boundary file as follows: Code:
boundary ( inlet { type mappedPatch; sampleRegion Fluid; sampleMode nearestCell; samplePatch none; offsetMode uniform; offset (0.15 0 0); faces ( (0 11 14 3) (3 14 16 5) ); } Code:
( inlet { type mappedPatch; inGroups List<word> 1(mappedPatch); nFaces 2000; startFace 887980; sampleMode nearestCell; sampleRegion Fluid; offsetMode uniform; offset (0.150 0 0); } Code:
boundaryField { inlet { type mapped; value uniform (0.0523 0 0); interpolationScheme cell; setAverage true; average (1 0 0); } Code:
Region: Fluid Courant Number mean: 0.00601751 max: 0.0959633 Region: ColdWall Diffusion Number mean: 0.00874827 max: 0.226531 Region: HotWall Diffusion Number mean: 0.00989324 max: 0.226531 --> FOAM Warning : From function bool Foam::functionObjectList::read() in file db/functionObjects/functionObjectList/functionObjectList.C at line 853 Caught FatalError --> FOAM FATAL ERROR: request for objectRegistry region0 from objectRegistry bfs failed available objects of type objectRegistry are 3 ( HotWall ColdWall Fluid ) P.S.: to better under the problem I'm trying to solve, you can have a look to the paper "Reference numerical database for turbulent flow and heat transfer in liquid metals" by Shams et al. (3rd paragraph). |
April 24, 2023, 17:57 |
CFD_Lovers
Rep Power: 11 |
Hello Alessandro,
Did you resolve the issue? I am trying to simulate a pipe flow using mapped B.C. However it look very strange since it produce only smooth averaged look profile of velocity while the simulation is LES. |
June 14, 2023, 09:36 |
Rep Power: 3 |
Hi, sorry for the very late reply. Concerning the forward step case, I was able to solve the problem by first simulating just the entrance channel until I got a fully developed flow. Eventually, I used the outlet profile as initial condition for the inlet of the step simulation. (an other solution could be to make the entrance channel longer enough to let the flow develop upstream the step, hence w/o the need of an initial simulation). I recently worked on an other simulation with a periodic channel flow (w/o conjugate heat transfer), but in that case I just used the "cyclicAMI" BCs.
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Cyclic boundary condition in foam-extend 4.0 | rellumeister | OpenFOAM Pre-Processing | 2 | March 3, 2020 09:03 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 02:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 07:49 |
