Multiphase flow with wave condition at inlet
Old   January 20, 2023, 21:50
Default Multiphase flow with wave condition at inlet
Andrew Mills
Drew.M is on a distinguished road
Hello all,
I am using openFOAM version 9
I am trying to simulate the wind and storm surge loading effects of a category 5 hurricane on a structure.
I want to simulate a inlet condition with water in the bottom section and air in the top section. This I can easily do with interFoam.
But to improve the accuracy of the physics of the problem, I want to impose a wave on the surface of the water at the inlet.
I understand that waves2Foam is for OF-V3 or older, but I also believe it to be a single phase solver which makes it not applicable to my application.
Using the boundary condition groovyBC for alpha.water and setting the values to be a function of time makes the most sense to me, but that would mean that my patch boundary will also have to change as a function of time which I don't think is possible.
I know what I want to do is possible. I know people have done this, or something very similar before. I know I am smart enough to figure it out eventually. But right now, I feel incredibly overwhelmed and I don't feel all that smart.
I know this isn't the right way to propose questions on this forum, but I seriously need a push in the right direction. I keep trying to change my google searches to try and find the correct explanation, but I'm in a feedback loop at this point finding the same articles and running into the same problems.
I am sorry this has turned into a therapy session partially, but in addition to the help with OF, I really want to hear about the thought process used by people with more experience in CFD. When you get stuck on a problem is there a plan of attack commonly used? Any and all help will be GREATLY appreciated.
Drew.M is offline   Reply With Quote
Old   January 25, 2023, 15:20
Andrew Mills
I was overthinking and stressing myself out.
If you want to run a similar simulation, look to waves2Foam solver, as well as the DTCHullWave tutorial!
hurricane, multiphase flow, wave
Wind tunnel flow simulation boundary condition issue charan3007 SU2 0 October 21, 2021 09:27
inlet boundary condition for open channel flow yaseen wsu CFX 3 April 7, 2016 19:30
Boundary condition in a multiphase flow giack OpenFOAM Running, Solving & CFD 0 April 2, 2013 05:46
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
urgent help...pressurize inlet for multiphase flow bernard CFX 0 November 2, 2006 06:18
