January 20, 2023, 17:08 |
Difference between interFoam and pimpleFoam
Farzad Faraji
Rep Power: 8 |
Hello all
I know that interFOAM is a multiphase solver and it is usually used for bubbly flow, but I want to use it as a single phase solver which I think it must work exactly like pimpleFOAM, but it is very slow compare to pimpleFOAM. why? The reason, I want to use interFOAM is that, I want to have p-rgh filed where pimpleFoam just gives p as an output. Thanks, Farzad |
January 20, 2023, 19:59 |
#2 | |
Farzad Faraji
Rep Power: 8 |
I checked the momentum equations(please see the attachment), and I am wondering if for single phase can I omit below red lines?
( mixture.surfaceTensionForce() - ghf*fvc::snGrad(rho) - fvc::snGrad(p_rgh) ) * mesh.magSf() with these changes, it will be similar to pimpleFoam with p-rgh term but it must run much faster. Thanks, Farzad Quote:
January 20, 2023, 22:08 |
I need "p-rgh" field
Farzad Faraji
Rep Power: 8 |
Hello again
Actually, I just want to have "p-rgh" field and either both below methods are fine to me; 1) Using interFoam which is too slow(is there any way to make it faster for single phase simulation?) 2) Adding gravity to pimpleFoam which one of the two methods are easier to implement? Thanks, Farzad |
interfoam, openfoam, p-rgh, pimplefoam |
Questions about simulation free surface open channel flow by interFoam and pimpleFoam | IsanM | OpenFOAM Programming & Development | 0 | September 10, 2020 04:13 |
Adapting interFoam's floatingObject tutorial for pimpleFoam | tecmul | OpenFOAM Pre-Processing | 1 | July 14, 2019 13:57 |
InterFoam (PimpleFoam) not obeying DeltaT in ControlDict | walakaka | OpenFOAM Running, Solving & CFD | 2 | March 1, 2018 13:57 |
Gravity & pressure handle in interFoam | dav.dap83 | OpenFOAM Programming & Development | 2 | May 22, 2013 12:21 |
Different solutions comparing pisoFoam and interFoam | AnjaMiehe | OpenFOAM Running, Solving & CFD | 8 | June 13, 2012 17:12 |
