rhoReactingfoam too small time step in supersonic nozzle
Old   January 20, 2023, 06:55
Default rhoReactingfoam too small time step in supersonic nozzle
atelcikti1's Avatar
atelcikti1 is on a distinguished road
Hi CFD fellows,
Currently i am trying to solve mixing (later laminar combustion) on liquid rocket motor. Species are some hydrocarbons, hcl, o2, oh, h2o so on so forth. I am using rhoReactingfoam for this. i am doing unsteady analysis and slowly increasing inlet mass flow rate (flowRateInletVelocity) for U, zeroGradient for P, pressureInletOutletVelocity for U and waveTransmissive for P at outlet then initializing domain with atmospheric conditions. At starting phase of analysis, solution seems like stable, but after some time, time step sizes reduces too much (ie. to 1e-12), so i observe no change in solution, even some variable matricies are not being solved. I am using maxco 0.5, initial stepsize 1e-7,1e-8 whatever doesnt matter at all. I am observing no recirculation at boundaries, no janaf temperature region warnings (i am limiting the numbers and expand the thermo properties until 20000K). Any idea about this strange behavior?
Thanks in advance.
atelcikti1 is offline   Reply With Quote
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
Convergence problem of OF WUYing OpenFOAM Running, Solving & CFD 2 September 20, 2021 11:09
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
