OpenFOAM simulation particles tracking
Old   January 18, 2023, 16:48
Default OpenFOAM simulation particles tracking
angelo
angel_97 is on a distinguished road
here is my first time that I use OPEN FOAM and I would like to simulate a straight channel in which I inject some particles (using Lagrangian discrete phase model).
I have used the DPMFoam in lagrangian, from the tutorial folder, but when I run, this message appears:
The DPMFoam solver has solver has been replaced by the more general
denseParticleFoam solver, which supports incompressible flow, including the
effect of the volume fraction of particles on the continuous phase, coupled to
multiple run-time-selectable lagrangian clouds.
To run with a single cloud rename the constant/*CloudProperties file to
constant/cloudProperties.
To run with a multiple clouds create a constant/clouds file with a list of the
names of clouds in it. Each cloud then has a corresponding
constant/<cloudName>Properties file.
In addition, cloud properties files also now require a "type" entry to specify
the type of cloud model used (e.g., thermoCloud, reactingMultiphaseCloud,
collidingCloud, etc ...).
See the following case for an example converted from DPMFoam:
$FOAM_TUTORIALS/lagrangian/denseParticleFoam/Goldschmidt
Thank you in advance for the help.
Best,
Angel
angel_97 is offline   Reply With Quote
Centrifugal fan impeller CFD simulation in OpenFoam ZachJa OpenFOAM 9 June 15, 2024 12:03
OpenFOAM course for beginners Jibran OpenFOAM Announcements from Other Sources 2 November 4, 2019 09:51
OpenFoam 4.1: interDyMFoam LES Simulation for hydro turbine in river pi__sec OpenFOAM Running, Solving & CFD 13 July 19, 2017 05:08
Ubuntu 12.10 + openfoam2.2.0 ==> paraview error message peteryuan OpenFOAM Installation 6 August 18, 2013 19:00
[OpenFOAM] ParaView ErrOr soheil nazmdeh ParaView 1 August 17, 2013 08:40
