Why does U not appear in fvSolution when using multiphaseEulerFoam?
Old   January 16, 2023, 11:43
Default Why does U not appear in fvSolution when using multiphaseEulerFoam?
JuanMi
keitaro7_14 is on a distinguished road
In the title is the question.
I am using OF-10.
In the tutorials pipeBend and titaniaSynthesis, for example, the field U is not needed in the fvSolution file, although the field is properly solved.
Why?
Thank you so much.
https://github.com/OpenFOAM/OpenFOAM...tem/fvSolution
keitaro7_14 is offline   Reply With Quote
Old   January 16, 2023, 13:41
Domenico Lahaye
dlahaye is on a distinguished road
Default settings are used.
dlahaye is offline   Reply With Quote
Old   January 16, 2023, 13:57
JuanMi
Thank you!!
some solvers complain (or did) if you didn't introduce the field in the fvSolution. I thought there was no default value.
Regards
MaxwellStefanFourier in multiphaseEulerFoam? deepblue17 OpenFOAM Running, Solving & CFD 2 October 14, 2021 06:32
Effects on fvSolution file on calling mpi run aaron99 OpenFOAM Programming & Development 0 May 27, 2019 07:12
How to lock the fvSolution file ? aaron99 OpenFOAM Programming & Development 5 May 17, 2019 12:44
Floating point exception Error from fvSolution sabago OpenFOAM Running, Solving & CFD 5 March 22, 2016 01:59
how to do the fvSolution configuration - SIMPLE Foam - complex cylinder geometry despaired student OpenFOAM Running, Solving & CFD 10 July 5, 2012 04:36
