multiphaseEulerFoam mass transfer / phase transfer |
January 16, 2023, 10:40 |
Rep Power: 8 |
hi all,
i want to do the following: i have 1 continuous phase and 2 dispersed phases (everything is same for the 2 dispersed phases (i.e. diameter, density, viscosity ...)) what i want to do is: insert only 1 dispersed phase from the inlet and when that phase enters certain cells i want to transfer that phase in the other dispersed phase. i tried using fvModels/fvOptions with sources and sinks for the thermo().rho()-field but could not achieve what i wanted. is there another option? maybe with phaseTransfer() in propertiesDict (unfortunately there is not one tutorial that uses it the way i want)? |
Coupled Heat and Mass Transfer | Mecroob | OpenFOAM Running, Solving & CFD | 1 | July 12, 2020 20:24 |
liquidEvaporation in simpleReactingFoam | neilk | OpenFOAM Programming & Development | 0 | May 16, 2019 20:37 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Source terms due to mass transfer in VOF model | ssamton | FLUENT | 0 | March 5, 2012 01:03 |
liquid phase reactions and mass transfer | Swarup | FLUENT | 0 | January 17, 2005 01:47 |
