Boundary Condition for rotating mesh w/ polynomial inlet profile
Old   January 13, 2023, 15:17
Default Boundary Condition for rotating mesh w/ polynomial inlet profile
Patrick
PatrickCFD is on a distinguished road
OF7 (no groovyBC)
What I have:
- Curved mesh that rotates around a fixed point outside of the mesh (via dynamicMesh)
- Inlet boundary condition is a polynomial profile, which means that the inlet flow varies across one axis (in the picture the red vertices depict the highest velocities). I have integrated the profile like this:
inlet
type fixedProfile;
profile polynomial
((-1.9 0 -1.0) (1 0 1))
direction (1 0 0);
origin 0;
The numbers in the double brackets determine the angle and the velocity of the inlet flow.
The Problem:
I have a transient simulation and the angle of the flow stays the same while the angle of the inlet changes during the rotation of the mesh.
What I would like to have:
I would like for the inlet flow to always be perpendicular to the inlet surface during rotation. I couldn`t find a suitable boundary condition that covers a mesh/inlet rotation plus a polynomial profile. I guess a fixedProfile type is the only one that allows polynomial profiles to be created?!
Thanks in advance.
PatrickCFD is offline   Reply With Quote
Old   January 24, 2023, 07:31
Patrick
I tried going down the "codedFixedValue" route. I use the following code:
code
const fvPatch& boundaryPatch = patch();
const vectorField& Cf = boundaryPatch.Cf();
const vectorField& n = boundaryPatch.nf();
vectorField& field = *this;
const scalar vmin = 25.597;
const scalar vmax = 35;
const scalar dmin = 24.5;
const scalar h = 9;
forAll(Cf, faceI)
const scalar x = Cf[faceI].x();
const scalar z = Cf[faceI].z()-33.5;
const scalar distance = pow(x*x+z*z,0.5);
const scalar faceVel = vmin + (distance - dmin) * (vmax - vmin)/h;
field[faceI] = faceVel*n;
Apart from the last line of code everything seems to work, at least run through. But the last line (57) messes up the whole thing.
The displayed errors are:
processor0/0/U/boundaryField/inlet:57:17: no match for »operator=« (operand types are »Foam::Vector<double>« and »Foam::tmp<Foam::Field<Foam::Vector<double> > >«)
- processor0/0/U/boundaryField/inlet:57:17: candidates are:
In file included from /opt/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/vector.H:39:0,
from /opt/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/point.H:35,
from /opt/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/pointField.H:35,
from /opt/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/edge.H:40,
from /opt/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/edgeList.H:32,
from /opt/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/PrimitivePatch.H:56,
from /opt/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/primitivePatch.H:35,
from /opt/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude/polyPatch.H:43,
from /opt/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude/fvPatch.H:39,
from /opt/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude/fvPatchField.H:47,
from /opt/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude/fixedValueFvPatchField.H:54,
from /opt/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude/fixedValueFvPatchFields.H:29,
from fixedValueFvPatchFieldTemplate.H:37,
from fixedValueFvPatchFieldTemplate.C:25:
I guess OpenFOAM wants me to use a vector or anything. But by choosing a vector I determine a direction which I don't want since I rotate the whole mesh (including the inlet). Maybe someone can make something of this. I'm thankful for the tiniest of responses.
boundary condition, codedfixedvalue, field[facei], polynomial profiles, rotating mesh
Using UDF to define velocity gradient boundary condition (not velocity inlet profile) uconcorde Fluent UDF and Scheme Programming 3 December 11, 2023 13:56
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Inlet boundary condition with existed velocity profile wanjia SU2 9 May 10, 2017 06:33
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
