simulate vacuum break in liquid helium cooled cavities |
January 13, 2023, 12:54 |
qutadah
Rep Power: 5 |
So I was wondering how I would start with this particular case in OpenFOAM. I will be simulating a vacuum break of liquid helium cooled tubes, and was wondering how to go about it. Air will be substituted with Nitrogen gas. I have simulated two phase incompressible flow using openfoam before and had used he multiPhaseEulerFoam solver, however I am not sure if there is anything readily available or even partially for this particular case. A little details about the case: 1- compressible flow. 2- condensation and frosting layer, mass deposition of the propagating nitrogen gas in the vacuum tube. 3- Heat transfer involved. 4- I will do 1D and then 2D. these are the basics I will start with ideally. Accepting suggestions and advice! I have never internally modified a case, so if that is the only option, please guide me to where I can start! Thanks! Regards, Qutadah |
gas dynamics, one dimensional flow, two dimensional model, vacuum case |
profile of liquid interface in dam break case! | vivek070176 | OpenFOAM Running, Solving & CFD | 3 | October 18, 2021 07:49 |
Simulate melting process of solid aluminium in liquid Titanium | anirudster | CFX | 8 | March 21, 2014 09:20 |
can FLUENT simulate the liquid film thickness | fadhil | FLUENT | 1 | March 11, 2009 06:48 |
can we Simulate air bubble inside hot liquid | Mohan | FLUENT | 0 | December 15, 2005 14:22 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
