MRF Rotating Wheel Case - can't remember how I did it |
January 13, 2023, 12:48 |
Alan w
Rep Power: 6 |
About a year and a half ago, I ran a rotating wheel case using MRF. Now I am revisiting it, and I am at a loss as to how I did it. What I am looking for is the sequence of commands that correspond to the case structure.
Attached is an image of the geometry, and also the tree images of the case structure. I approximated wheel "squish" by siting the wheel in a slab with a a divot in it. My usual practice is to document the methods I used in building the case, but somehow I dropped the ball on this one. For example, what command caused the polyMesh folders for wheel and solid to be created in the constant folder? Or, maybe someone can give me a link to a tutorial that shows how to simulate a rotating wheel with MRF zones? Thanks in advance if anything transpires! |
January 21, 2023, 06:09 |
Nikos
Rep Power: 14 |
The rotatingCylinders tutorial ($FOAM_TUTORIALS/incompressible/simpleFoam/rotatingCylinders) may be useful:
https://www.openfoam.com/documentati...inders-2d.html All the best |
MRF and topoSet problem- Rotating volume doesn't rotate | andreas0209@hotmail.com | OpenFOAM | 1 | April 4, 2021 14:35 |
Structural prestress analysis on a rotating wheel fixed at center with rpm as load co | SaiPrasad Chowdavaram | Structural Mechanics | 7 | September 28, 2020 03:42 |
Continuity error cannot be removed by adjusting the outflow - rotating domain case | Swift | OpenFOAM Running, Solving & CFD | 4 | July 10, 2017 09:36 |
Moving Wall, MRF or Sliding Mesh for modelling rotating rim and tyre? | Field85 | FLUENT | 3 | March 18, 2016 11:09 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
