Antonio Lau
Rep Power: 3 ![]() |
Dear all,
Im a beginner in Open Foam so it could be that the problem is obvious but also after searching online I couldnt find something. I tried to do the elbow tutorial with the help of following video : https://youtu.be/KznljrgWSvo. After the meshing, evrythng looked fine but as soon as i trie to execute the icoFoam solver following error apears. -> FOAM FATAL ERROR: (openfoam-2212) cannot find file "/home/alaur/elbow/0/p" From virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::rea dStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 561. FOAM exiting Grettings Last edited by Anton21; January 28, 2023 at 05:20. |
beginner |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 4 | September 25, 2023 07:10 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
mesh.update problem in a new FSI solver | ICL | OpenFOAM | 0 | October 8, 2011 14:16 |
Coupled solver energy equation problem | lucioantonio | FLUENT | 0 | April 3, 2009 10:21 |
