FOAM FATAL ERROR: Maximum number of iterations exceeded: 100
Old   January 10, 2023, 11:57
Default FOAM FATAL ERROR: Maximum number of iterations exceeded: 100
mo
gmori is on a distinguished road
Hi,all.
I am using chtMultiRegionSimpleFoam to analyze a fluid domain on top of a solid (ground). I am using the view Factor model to calculate the radiation in the fluid. The analysis conditions are shown below.
air/changeDictionaryDict:
boundary
inGroups 2(wall viewFactorWall);
U
internalField uniform (0 0 0);
boundaryField
type fixedValue;
value uniform (0 0 0);
inlet
type fixedValue;
value uniform (0 0 -0.6);
outlet
type zeroGradient;
T
internalField uniform 303;
boundaryField
type externalWallHeatFluxTemperature;
mode coefficient;
kappaMethod fluidThermo;
Ta constant 303.1;
h constant 3.6;
value uniform 303;
qr qr;
qrRelaxation 0.3;
"air_to_.*"
type compressible::turbulentTemperatureRadCoupledMixed;
Tnbr T;
qrNbr none;
qr qr;
value uniform 308;
inlet
type fixedValue;
value uniform 303.1;
outlet
type zeroGradient;
epsilon
internalField uniform 0.000278;
boundaryField
type epsilonWallFunction;
value $internalField;
inlet
type turbulentMixingLengthDissipationRateInlet;
mixingLength 0.028;
outlet
type zeroGradient;
k
internalField uniform 0.00135;
boundaryField
type kqRWallFunction;
inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.05; // 5%
outlet
type zeroGradient;
p_rgh
internalField uniform 101325;
boundaryField
type fixedFluxPressure;
inlet
outlet
type fixedValue;
value uniform 101325;
p
boundaryField
type calculated;
inlet
type calculated;
outlet
type calculated;
qr
internalField uniform 0;
boundaryField
type greyDiffusiveRadiationViewFactor;
emissivityMode lookup;
qro uniform 0;
emissivity uniform 0.9;
value uniform 0;
"air_to_.*"
emissivityMode solidRadiation;
qro uniform 0;
value uniform 0;
G
boundaryField
type MarshakRadiation;
emissivity uniform 1.0;
value uniform 0;
"air_to_.*"
value uniform 0;
IDefault
boundaryField
type greyDiffusiveRadiation;
value uniform 0;
"air_to_.*"
value uniform 0;
alphat
boundaryField
type compressible::alphatWallFunction;
Prt 0.85;
inlet
type calculated;
outlet
type calculated;
nut
boundaryField
inlet
type calculated;
outlet
type calculated;
type nutkWallFunction;
In this case, the error FOAM FATAL ERROR: Maximum number of iterations exceeded: 100 appears. I can see that there is a temperature anomaly
I can see that there is a temperature anomaly, but I can't find a solution. Can anyone help me?
Time = 268
Solving for fluid region air
DILUPBiCGStab: Solving for h, Initial residual = 0.04095449, Final residual = 0.0003494682, No Iterations 1
Min/max T:1.324802e-91 7.482229e+13
Solving for solid region soil
DICPCG: Solving for h, Initial residual = 0.03252537, Final residual = 3.142769e-05, No Iterations 1
Min/max T:300 7.886081e+11
ExecutionTime = 41.87 s ClockTime = 43 s
Time = 269
DILUPBiCGStab: Solving for h, Initial residual = 0.03618418, Final residual = 0.000299067, No Iterations 1
Min/max T:7.895323e-104 7.493647e+13
DICPCG: Solving for h, Initial residual = 0.02955888, Final residual = 2.546186e-05, No Iterations 1
Min/max T:300 8.278574e+11
ExecutionTime = 42.01 s ClockTime = 43 s
Time = 270
DILUPBiCGStab: Solving for h, Initial residual = 0.03243137, Final residual = 0.0002599866, No Iterations 1
Solving view factor equations for band : 0
Min/max T:4.705317e-116 7.504548e+13
DICPCG: Solving for h, Initial residual = 1, Final residual = 0.004184222, No Iterations 1
--> FOAM FATAL ERROR:
From Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::rho Const<Foam::specie> >, Foam::sensibleEnthalpy>]
in file /home/dexcs/OpenFOAM/OpenFOAM-v2006/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 75.
FOAM aborting
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::error::exitOrAbort(int, bool) at ??:?
#2 Foam::heSolidThermo<Foam::solidThermo, Foam:ureMixture<Foam::constIsoSolidTransport<Foa m::species::thermo<Foam::hConstThermo<Foam::rhoCon st<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() at ??:?
#3 Foam::heSolidThermo<Foam::solidThermo, Foam:ureMixture<Foam::constIsoSolidTransport<Foa m::species::thermo<Foam::hConstThermo<Foam::rhoCon st<Foam::specie> >, Foam::sensibleEnthalpy> > > >::correct() at ??:?
#4 ? in ~/OpenFOAM/mori-v2006/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam
#5 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6
#6 ? in ~/OpenFOAM/mori-v2006/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam
gmori is offline   Reply With Quote
Old   January 11, 2023, 11:21
Peter Hess
peterhess is on a distinguished road
Hello!
The conditions looks good.
The only change I could suggest is to change the velocity at the outlet from zeroGradient to inputOutput.
Is ist possible, that your mesh has wrong dimensions and is too big?
Run checkMesh please and post the results.
Try also emissivityMode lockup;
for G and IDefault in the region air_to_.*
Regards
Peter
peterhess is offline   Reply With Quote
Old   January 11, 2023, 11:58
mo
Thank you for reply!
I'll change the outlet condition and the emissivitymode!
The results of checkMesh are attached below.
Create time
Create mesh for time = 0
Time = 0
Mesh stats
faces: 2387600
internal faces: 2335600
cells: 787200
faces per cell: 6
boundary patches: 16
point zones: 0
face zones: 0
cell zones: 2
Overall number of cells of each type:
hexahedra: 787200
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
soilmaxY 1440 1573 ok (non-closed singly connected)
soilminX 960 1053 ok (non-closed singly connected)
soilmaxX 960 1053 ok (non-closed singly connected)
soilminY 1440 1573 ok (non-closed singly connected)
soilminZ 9600 9801 ok (non-closed singly connected)
glassmaxY 4800 4961 ok (non-closed singly connected)
glassminX 3200 3321 ok (non-closed singly connected)
glassmaxX 3200 3321 ok (non-closed singly connected)
glassminY 4800 4961 ok (non-closed singly connected)
twincarbmaxY 3600 3751 ok (non-closed singly connected)
twincarbminX 2400 2511 ok (non-closed singly connected)
twincarbmaxX 2400 2511 ok (non-closed singly connected)
twincarbminY 3600 3751 ok (non-closed singly connected)
roof 9472 9703 ok (non-closed singly connected)
inlet 64 81 ok (non-closed singly connected)
outlet 64 81 ok (non-closed singly connected)
Checking faceZone topology for multiply connected surfaces...
No faceZones found.
Checking basic cellZone addressing...
CellZone Cells Points Volume BoundingBox
soil 115200 127413 2.88 (0 0 0) (6 4 0.12)
air 672000 695871 81.12 (0 0 0.12) (6 4 3.5)
Checking geometry...
Overall domain bounding box (0 0 0) (6 4 3.5)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (-3.451071e-18 -3.69474e-17 2.42457e-17) OK.
Max cell openness = 1.845451e-16 OK.
Max aspect ratio = 5 OK.
Minimum face area = 0.0005. Maximum face area = 0.0025. Face area magnitudes OK.
Min volume = 2.5e-05. Max volume = 0.000125. Total volume = 84. Cell volumes OK.
Mesh non-orthogonality Max: 0 average: 0
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 1.421085e-13 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
Old   January 12, 2023, 12:30
Peter Hess
The mesh looks good.
Take a look here and see, if the radiation setups in your case are right:
Adding Radiations in chtMultiRegionSimpleFoam
Post the case if you want, so I could have a closer look to it.
openFoam version?
Regards
Peter
Old   January 14, 2023, 05:14
mo
Thanks for the info!
I am using OpenFOAM ver2006.
I also changed the output condition to inletOutlet and the emissivityMode to lookup, but the error was not resolved.
laplacianFoam with source term Herwig OpenFOAM Running, Solving & CFD 17 November 19, 2019 14:47
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
formatted point data- icem HSK CFX 12 August 11, 2011 22:25
